Results 1 to 12 of 12
Thread: Pontoon repair and back purge
    Sep 2016
    Near Traverse City, Mi.
    When repairing or modifying a pontoon would you need to fill the toon with argon?
    I have not started repairing yet but intend to eventually.
    Several threads discuss purging but none say when and why.
    Oct 2009
    Austin TX
    Re: Pontoon repair and back purge
    I never back purge anything that isn't going to have something important flowing inside it.
    Miller Syncrowave 350
    Millermatic 252/ 30A spoolgun
    Miller Bobcat 225g w/ 3545 spoolgun
    Lincoln PowerArc4000
    Lincoln 175 Mig
    Lincoln 135 Mig
    Everlast 250EX Tig
    Century ac/dc 230 amp stick
    Victor O/A
    Hypertherm 1000 plasma
    East Tennessee
    No need to purge. I've worked on a bunch of them with no problems. Would be expensive to purge, lots of volume.
    Oct 2011
    Hamlin, NY
    Only if you're getting paid to waste time and money...
    Ryan
    CK WF1 TIG wire feeder
    Miller Spectrum 375 Xtreme
    Optrel e684
    Miller Digital Elite
    Miller Weld-Mask
    Mount Tabor VT
    I presume it's aluminum. Open it to let expansion escape. If installing a patch, put a backer behind the flush patch to trap argon. A patch that overlaps needs no additional backer. Were it stainless, you'd need argon back there to prevent oxidation while it's hot. With aluminum all you need is to avoid turbulence bringing air into your weld. A gas lens helps.
    Willie
    Jul 2013
    Any reason to be weary of explosive gas build up in damaged pontoons?
    Central Ohio
    I work on pontoon repairs all the time . No need to purge and no there's no gasses. If you pressure the tube to check for leaks use no more the around 5 psi. Air only.
    McGregor, Iowa
    Had these dropped off at the shop this week, needs a few holes and cracks patched back up. They are 45 footers long and 3 foot diameter x2. I spent about 8 hours the other day grinding out cracks and rewelding them up. The XR-A got a workout on these. I would never purge out something so massive. If it was something with that much flammability I would fill it up as far as I could with water and then purge it so I didn't waste so much gas.
    Mar 2006
    Yuma, Arizona
    Cool project.
    When you finish it, grab your polisher. 5052 shines up real nice with some Meguiars polishing compound! I did mine and it was incredible.
    Lincoln Power Mig 210MP MIG
    Lincoln TIG 300-300
    Lincoln Hobby-Weld 110v Thanks JLAMES
    My brain
    Sep 2005
    Cave Creek AZ
    Only time you need to worry is when welding on pontoon that look like these
    Sep 2014
    Greensburg Pa
    Want to update this thread with a caution to welding pontoons. I have done one myself and had no problem but i have read a post where some guy said his neighbor or maybe it was a competing weld shop that welded on a pontoon and the thing exploded due to built up gasses and severly injured the guy.
    I believe it was prob due to a foam or some substance inside the pontoon. I cant possibly see how a hollow pontoon would do such a thing (even completely sealed up) but just giving a heads up guys cuz no one else said it in this thread. Be careful with what ur welding and make sure there isnt any flamable substance on the backside of those welds guys.
    Dynasty 200DX (2014)
    Millermatic 211 (2015)
    Optrel 864 (2014)
    Smith Medium duty MBA 30510 (Xmas 2014)
    Tennsmith 16ga 4ft finger brake (2015)
    Trailblazer 325 EFI and excel
    Thermal dynamics Cutmaster 82
    Miller maxtron 450
    Oct 2011
    Hamlin, NY
    If someone exploded a pontoon, there's many things done wrong... No offense but sounds like a Darwin Award....
    Sent from my LM-Q710.FG using Tapatalk
    Ryan
    Optrel e684
    Miller Weld-Mask
Page generated in 1,713,253,684.46868 seconds with 19 queries
