Results 1 to 12 of 12
Thread: How to weld this without distortion
    Dec 2015
    I have an arbor flange from a mower deck i want to repair. The flange has a cavity which I would like to fill and then grind smooth. I'm concerned the shaft will not be plumb if there is heat distortion. Any suggestions on how to prevent distortion ?
  2. Dislikes Hobbytime disliked this post
  3. #2
    Mar 2005
    Under a Rock
    Re: How to weld this without distortion
    I'd just mig it and grind it flat.
    whats the story with it?
    factory defect? Or were you sharpening up rocks with the mower blades?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Dec 2015
    I only have a stick welder. It is a factory defect. installed, the mower blade will cover the flange.
  5. Dislikes Hobbytime disliked this post
  6. #4
    Jan 2006
    In A Nice Comfy Chair
    Just do it and get it over with.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
  7. #5
    Oct 2016
    Delavan WI
    Clamp it down
  8. #6
    Delaware
    Clean it out with a burr, then a pass with 6013, 7014 or 7018, grind it smooth your done.
  9. #7
    As stated just weld it up. IF it moves just set in vise and use a BFH to wack it plumb. Set on table and use shim and clamps to plumb up.
  10. #8
    Dec 2015
    thanks.
  11. Dislikes Hobbytime disliked this post
  12. #9
    Oct 2011
    Elkhorn, WI
    I've welded those basically like these guys describe with no distortion issues. Some of the earlier ones I Stick welded with small diameter rod (probably 6011 or 13). The later ones I mig welded only because it was convenient and out of small diameter arc rod.
  13. #10
    SoCal-LA
    Leave it alone. It is not cracked and the maker obviously had no issue with it.
    On the other hand if you are OCD, just fill and grind.
  14. #11
    Oct 2011
    Hamlin, NY
    "Defect" the blade mount is plug welded to the shaft. It's not going to fail even the way it it. If you're worried about balance, even that would be minimal as it is nearly at the centerline of rotation. Welding it with any means probably won't induce any warpage, you're just finish filing up the plug weld, no fillet, you're not welding on the side of the shaft. First rock you hit mowing will throw it more out of balance than any welding you do. Seriously you worrying about nonsense.
    Ryan
    CK WF1 TIG wire feeder
    Miller Spectrum 375 Xtreme
    Optrel e684
    Miller Digital Elite
    Miller Weld-Mask
  15. #12
    Seriously, this is a case of welding being a solution in search of a problem...
Page generated in 1,635,281,792.43071 seconds with 13 queries
