Results 1 to 3 of 3
Thread: standard or stubby gas lens....More heat????
    Jan 2013
    I've been using stubby gas lenses on my 17 tig torch. Thought I ordered more of the same, but got the standard size parts. Just wondering, would using the standard parts instead of the stubby parts help keep the torch cooler/hotter because the pieces are much larger and either dissipate or conduct more heat into the torch. Anyone have the answer????
    Thanks,
    Pete
    Everlast i210 with 200a spool gun
    Everlast i140e
    LOTOS LTP5000D Non-Touch Pilot Arc
    "Things are never so bad that they can't get worse...."
    Delaware
    Re: standard or stubby gas lens....More heat????
    It really don't matter standard or stubby the torch will still get hot.
    If you want cool go water cooled. You can run your AHP wide open and the torch will never get hot.
    Feb 2014
    Iowa
    I'm sure with the right testing you may find a difference, but practically, I'd say you won't be able to notice it.
    Miller Dynasty 350
    Miller CP300
    Miller CP200
    Lincoln Idealarc 250/250
    Smith torch
    Lagun FTV-2
    Kent 13x40 TRL lathe
    Bunch of other metal cutting tools
Page generated in 1,713,258,765.14666 seconds with 18 queries
