Razor Cut 45 torch
9.4K views 16 replies 6 participants last post by  KMA
Hi folks,
I've just bought my first plasma cutter, a Razor Cut 45, from RazorWeld.
First thing I noticed is that the provided torch is not the advertised "High Quality TRF-45-6-CC1 Plasma Torch" from the brochure, box, manual, etc.
Basically, I'm looking for some points of view to know if what I got is better/worse/the same and if I should be pissed off and demand the correct torch before starting to use it, or truck on with it (and find out what consumables it will take, instead of the Trafimet S45 stuff mentioned in the manual). I read another thread and this may me a PT40, but I'm not sure at all. I have never used another plasma cutter or torch.
Here's a photo of what was in the box. It came with a different tip mounted (drag tip?) and an additional regular tip, and additional, skinnier electrode. No stand off guide. One thing I want to be able to do is to best follow a straight edge or template for hand held cutting.
Thanks for any advice.
#4 ·
Thanks, I did read that thread and your posts, but probably a bit too fast. Looks like my torch is exactly the same as the one you got. Then on page 8 and post #199 there's one with the same body but very different nozzle, seems better for dragging purposes. Seems like everybody in that thread is still pretty confused about what the torch is and what consumables it takes. Someone says PT40, then there is an image posted about pin configuration for an S45 and it's the exact same torch, with a purple color. I'll send an email to the company for more info.
#7 · (Edited)
#10 · (Edited)
Buy the original Italian stuff if you can..
I only really know what is good in the S-45 stuff. Some of the Ebay China companies have the option for real Italian made consumables.. That's where your best deal is.. Like ten nozzles for under $23.00 with Free shipping.. Have to dig for them a bit, but you don't even have to buy from Ebay either.. They are on-line too..:cool:
I am using the harder to find .065MM nozzles on my new 120 volt/ 20 amp machine, and those are the tough ones to get deals. .08 mm, and .09 mm nozzles are everywhere. (good ones too..)
#14 ·
Let me try and clear up some of the confusion between the PT (Italy)/IPT (China) torch and the Traifmet S45 torch (Italy) and S45 copys (China).
First the Traifmet S45 from Italy is a top of the line torch. The S45 from China work somewhat. And is what is called a front striking/blow-back pilot arc torch.
The Tecmo PT torch from Italy is top of the line torch. The IPT torch from China works well but not made with the best materials. And is whats called a back striking pilot arch torch.
Now in the pictures I will be posting you will see a lot of the differences between them. The biggest difference is the travel of the plunger (the part the electrode screws into)
The S45 plunger moves about twice as far as the PT does. You only need the plunger to move a little on the PT back striking to brake the contact and start the arc. As were you need about twice the range to start the arc with the S45. You can e see this in some of the pictures.
The PT/IPT torch has a lot of advantages over the S45 as far as consumables. The biggest one is the shielded consumables used on a lot of the higher priced plasma cutters on the market. I have put some of them in the pictures.
Now A lot of people have been using the S45 consumables on the PT/IPT torch's and they will work well. But you will not get the best performance from them as the torch was designed for the back striking consumables as well as air flow through the torch and around the electrode and tip/nozzle
On the other hand the back striking consumables will not work at all in the S45 torch. Ask everyone that calls me because there plasma cutter won't strike an arc after buying the consumables from Harbor Freight for there older plasma cutters, or other people that used to get the S45 consumables from HF for there plasma cutters.
Ok, anyone have any questions can contact me by phone, email, PM, etc. and I will go over it in more detail with you.
In the pictures everything on the left will be the PT/IPT on the right will be the S45
