Just my two cents...sorry for bumping...
I drill thousands of holes annually in most metals and some plastics. Yes, I do "keep score" regarding how many hundreds of inches of material a certain drill bit can penetrate. My shop machines everything from plastics to steel that is nearly 60 Rockwell C.
Sharpen drill bits? I only sharpen drill bits that are larger than diameter 0-1/2". Used correctly many bits have "collapsed" flute edges by the time their point is worn to the need for sharpening and will have a problematic performance after sharpening. In essence; they are not worth grindng.
In an emergency I will use a drill point gauge and grind one by hand. That is a skill that is all but lost I guess and even I am not a fan of it. As soon as a replacement is available that bit will hit the scrap can.
None of the "home shop" drill bit grinders I have seen will make a correct point on a drill bit. Drill bit grinding is every bit as serious as the grinding of other cutters and requires specialized machinery that one does not purchase for a few hundred dollars.
So, even though there are at least three (03) established and common point angles and web and helix types and materials from that drill bits are made; what would I recommend to someone who wants to drill everything from soft materials all the way through steel hardened into the high 40's Rockwell C?
Very simply this: Select drill bits made from M42 Cobalt like this types
https://mechanicguides.com/best-cobalt-drill-bit-sets/ alloy high-speed steel with a heavy web and a 135-degree split point or "crankshaft grind" as the old fellows call it. Purchase such tools only from American or a select few European makers.
TiN (Titanium nitride) coating? Only if you do as I do and expect a drill bit to produce a few hundred to a few thousand holes. Otherwise you might as well pour your money down the sink. Carbide? Only for very special applications with super accurate machine spindles.
The common twist drill bit is still the most efficient metal removal tool ever designed regarding cubic inches/horsepower/minute. It is also the most abused metal removal tool ever designed.
McMaster-Carr pricing is fine. Another source is Suncoast Precision Tools
https://www.suncoasttools.com/
The worst gimmick? Anything that is TiN coated and made in China or India. Buy cheap, expect garbage. A plain Jane American simple high-speed steel uncoated drill bit will outperform these gimmicks any day.
Just some suggestions and one good video from Youtube, that I hope will help.
[video=youtube;hDM4zsk77AI]https://www.youtube.com/watch?v=hDM4zsk77AI[/video]
