Results 1 to 11 of 11
Thread: New 62204 Consumables Available
    Delaware
    Drag tips, 20 to 40 amp un-shielded and 30/40 amp shielded
    Re: New 62204 Consumables Available
    Would the shield tip kit fit the RazorCut 45's torch? Thanks
    Everlast PowerMTS 211Si
    Delaware
    Yes all of it will.
    Aug 2016
    Southern California
    Already put my order in yesterday
    May 2010
    laguna niguel, Ca USA
    This work on the pt-60 torch ?
    Sent from my LG-K550 using Tapatalk
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Smith Gas Mixer AR/H
    Tig is my Kung Fu
    Throwing down dimes and weaving about
    Instagram http://instagram.com/weldor_wes
    WeldorWes@WcWeldingLLC.com
    Delaware
    Quote Originally Posted by WeldorWes View Post
    Yes all these will work on the PT60 torch. Consumables from 20 to 60 amps.
    Yes all of it will.
    Thanks. Do you have any feedback on the shielded consumables vs the drag on the IPT40 torch? I have some nice Italian parts but I'd like to try out other options.
    Merry Christmas everyone.
    Delaware
    Let me try and clear up some of the confusion between the PT (Italy)/IPT (China) torch and the Traifmet S45 torch (Italy) and S45 copys (China).
    First the Traifmet S45 from Italy is a top of the line torch. The S45 from China work somewhat. And is what is called a front striking/blow-back pilot arc torch.
    The Tecmo PT torch from Italy is top of the line torch. The IPT torch from China works well but not made with the best materials. And is whats called a back striking pilot arch torch.
    Now in the pictures I will be posting you will see a lot of the differences between them. The biggest difference is the travel of the plunger (the part the electrode screws into)
    The S45 plunger moves about twice as far as the PT does. You only need the plunger to move a little on the PT back striking to brake the contact and start the arc. As were you need about twice the range to start the arc with the S45. You can e see this in some of the pictures.
    The PT/IPT torch has a lot of advantages over the S45 as far as consumables. The biggest one is the shielded consumables used on a lot of the higher priced plasma cutters on the market. I have put some of them in the pictures.
    Now A lot of people have been using the S45 consumables on the PT/IPT torch's and they will work well. But you will not get the best performance from them as the torch was designed for the back striking consumables as well as air flow through the torch and around the electrode and tip/nozzle
    On the other hand the back striking consumables will not work at all in the S45 torch. Ask everyone that calls me because there plasma cutter won't strike an arc after buying the consumables from Harbor Freight for there older plasma cutters, or other people that used to get the S45 consumables from HF for there plasma cutters.
    Ok, anyone have any questions can contact me by phone, email, PM, etc. and I will go over it in more detail with you.
    In the pictures everything on the left will be the PT/IPT on the right will be the S45
    Wow, what a terrific write up George. Thank you!
    Aug 2016
    Southern California
    And got them today, great service ,thanks
    Delaware
    Got some pictures of some of the new consumables in stock for the 62204.
    I posted the 60 amp set I know, but it comes in 40 amp also.
Page generated in 1,623,659,760.60506 seconds with 12 queries
