Results 1 to 25 of 35
Thread: Newbie dilemma – help with first welding table
Hybrid View
    To preface, I am new to welding and fabrication. I just finished cutting the steel square tubing for my first welding table. I unknowingly ordered a much heavier gauge than I wanted, but it's cut and I can't return or exchange it, so I'm stuck with it. My question is, is my welder powerful enough to effectively weld this thing together? Here's the welder and steel for the table (overkill, I know):
    Welder: Lincoln 140amp MIG
    3/8" plate (table top)
    2x2 : 3/16" (frame)
    3x3 : 1/4" (legs)
    Thanks!!!
    PDX PNW
    Re: Newbie dilemma – help with first welding table
    Just the legs are over kill. U will be fine weld it up no problem. My 3/4 bench is sitting on a wood frame
    What is the dimensions of the table ??? Not overkill as far as I'm concerned.
    Can you drive your 140A mig to full power? Usually you need a 30A to truly get full power out of a 110A mig. What does your owner's manual say about running at full power? And if it indeed needs a 30A current input, can you properly supply that to the machine??
    63"x33"
    Dec 2016
    Ventura County, CA.
    What did you end up paying for the steel you bought for the table?
    I'm flipping a coin now, build or craigslist!
    If you want to learn no one can stop you.
    Hobart Handler 175 / AHP AlphaTig 200X V4 / HF 95136 Plasma
    Quote Originally Posted by BruceinLA View Post
    Like I said, I went overboard and bought heavy gauge steel. Cost me around $400 for the plate and tubing from Wexler in Chicago.
    Western New York State, USA
    Quote Originally Posted by Neophyte View Post
    2x2 : 3/16" (frame)
    3x3 : 1/4" (legs)
    Thanks!!!
    you might try .030 instead of .035 wire. and multipass welds. use 3 passes instead of trying to make 1 big pass
    personally i would stick weld it but if all you got is the MIG try welding some scrap small pieces for practice first at full power and see what you get. 3/8 plate is thick, grind off mill scale to help with weld penetration
    Nov 2015
    Beacon and Pawling, New York
    You can also get more out of your machine by running C02. You'll need an adapter for your regulator. Running a 30 amp outlet for your machine will pay off in the long run. 140 amp machines are unloved generally because few are ever run off a proper outlet. They are much more capable than people give them credit for.
    Dec 2007
    Los Angeles
    Don't worry about the top as you don't need/want to weld it on- just a couple of beads around so it holds it in place.
    You can run the fluxcore in that machine and will do just fine for this application.
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
    Jan 2016
    Michgan
    Another thing remember the duty cycle of the welder. Which mean that if you running full out or max the welder you need to give it a break to cool off.
    Klutch 220si mig , stick, and dc tig
    Hobart 140
    AHP ALPHA 200X 2016
    Lotos LTP5000D
    Smith O/P
    It's 33"x63"x3/8"
    I can have the voltage knob maxed out ("D" setting on my Lincoln Electric 140). Is that what you mean?
    Oct 2011
    Elkhorn, WI
    Bevel the joints and multiple pass as already suggested. CO2 and 0.030" Mig wire or Fluxcore as suggested above.
    Quote Originally Posted by drujinin View Post
    Thanks for the advice! Is it 100% CO2? I have a 5lb can with regulator hooked up to a keg that might fit my welder.
    Dec 2007
    Los Angeles
    Yup - same stuff.
    Ed Conley
    MM252
    MM211 (Sold)
    SO 2020 bender
    Beer in the fridge
    Cleveland, Ohio
    This came in this week where I workName:  20161230120310252_L.jpg
Size:  55.2 KB. Custom job. We all love the spider webs!
    Gina M. Tabasso
    HGR Industrial Surplus
    gtabasso@hgrinc.com
    www.hgrinc.com
    Mar 2016
    Minneapolis MN
    63 x 33 would be a nice size table. I suggest that you cut small pieces of your stock for the legs and frame - 2" long or so - and practice welding them together until you get good results. Keeping the frame square and level will be a challenge. Also keeping the table top from warping when you attach it to the frame will be the next challenge. Some people use mechanical fasteners. You want the top to be as flat as possible.
    Quote Originally Posted by cloudman View Post
    Thanks cloudman. I managed to flatten the plate by clamping some 3/16 tubing to it which pulled the warp out. I'm going to do that when i weld the frame to the plate. Did some practice welds which actually came out fairly well.
    Jan 2014
    First state
    What cloudman said... practice on the same material, so you know that you are getting proper penetration.
    I just built this table; a 36 x 61 x 1/2", using pretty much the same square tubing as you bought, except all mine is 2x2. I do have a heavier duty welder, but you can do it with that one. I used 1/2" flat-head socket bolts to install the top, as I didn't want to weld the top on. This way, later, I can easily shim a bowed top, or even remove it. I welded small gussets to the inside corners of the frame, and welded nuts to the back of those. Then I simply drilled and countersunk the mounting holes. If you decide to so the same, I have a lot of extra 1/2x2 flat socket-head bolts.
    PrimeWeld 225X TIG
    Millermatic 180 Mig
    Lincoln IdealArc 250
    Thermal Dynamics Cutmaster 42
    Cut50 Plasma cutter
    Craftsman(1980) buzzbox purchased new
    Aug 2013
    Quote Originally Posted by Will S. View Post
    Are the drawers attached to the table or just sits in there?
    Jan 2014
    First state
    Quote Originally Posted by ICEcap View Post
    I built the table frame and cabinet supports to allow easy installation and removal. I completely finished the table, and painted it before installing. To remove, I simply push it back 2", then tip the top backwards, and lift the bottom up, and slide it completely out the end of the table. When I got the tool cabinet, I measured the distance diagonally, from the bottom front to the top at thr back. That is what it neded to clear the underside of the steel top, so that it can be slid out. I welded the lower table frame to give me just the needed clearance.
    On edit; this pic might give you a better idea of how the cabinet sets. Notice that on the rear support for the cabinet, the flange is facing down, so the cabinet can be slid back. So far, it hasn't moved from closing the drawers with weight in them, but I might screw a small bracket or fender washer to the support, to keep the cabinet from being pushed back.
    PrimeWeld 225X TIG
    Millermatic 180 Mig
    Cut50 Plasma cutter
    Great looking table! How tall is it?
    Jan 2014
    First state
    Thanks!. With the home-made leveling feet, height can be adjusted from 36" to 40". I have it set to just over 36". I used 5" grade 8 bolts, welded to 1/4" discs I cut out of a piece of flat bar, so they could easily be removed (to 35.5"), or xchanged for something else, for more height.
    PrimeWeld 225X TIG
    Millermatic 180 Mig
    Cut50 Plasma cutter
  25. #25
    If you try CO² with solid wire, at best your machine is going to be able to output around 100 amps. Your best bet for 3/16" and 1/4" with your machine would be an .030 or .035 E71T-11 self shielded fluxcore wire. A little pre-heat will help some too. Use tight stringer beads with minimal side to side oscillation
    ESAB Migmaster 250
    Hobart Ironman 230
    Multimatic 215
    TWECO Fabricator 181i & 211i
    Maxstar 150 STH - very nice
Page generated in 1,664,392,433.55777 seconds with 12 queries
