Welding bevel washer
6.8K views 27 replies 10 participants last post by  snoeproe
So i need to weld mallebale cast iron bevel washers to the flange of C channel, then weld the nut to the washer. I have to weld these parts since they will be inaccessible to put a wrench on them. Normally if it was in a low stress aplication I would MIG the cast washers, but this time its alot of force on the washers. Im not sure if I can get away with a couple good sized MIG tacks or even some 7018. I just don't want to have the washer crack and fail due to the welds since it will be a major PITA to re-access the washers/nut.
#2 ·
What you could do is make your own bevel washers by cutting from the flanges of channel iron. Just drill your holes before cutting. If there is that kind of stress on the washers, that would be more sound than malleable ones.
#4 ·
I had a 10" S beam that I had to bolt onto plates, and didn't have bevel washers. Cutting them is what I did. Worked out good. Is this on your press? Been following it some on GJ.
#6 ·
If you can find some threaded rod nuts long enough, just cut them in half at the appropriate angle and weld.
#7 ·
You will require a mag drill to drill bolt holes in c channel prior to cutting beveled washers from it.
Are you sure these are cast iron?
Beveled washers are very common with the ironworker trade and structural steel erection. I've never seen cast iron beveled washers.
#8 ·
Why would you need a mag drill? I drilled the ones I made on a regular drill press. Just drill them before cutting. If I recall the metal is a little sketchy on the washers, but I don't think they are cast.
#11 ·
f150skidoo
Not all bolt-houses are the same - nor is the quality of bevel washers.
Your [photo] example is all I have ever seen at industrial-retail outlets.
For: a 'know/spec product', you have to go to a real bolt-house. Said
houses
: are not generally open to the public, require an account, only
accept phone orders, may or may not - have will-call; and they want to
sell in keg quantities.
They have all of the goodies - but small quantities can be hard to get.
Search the sights that project type specifications . . .
http://www.google.com/search?q=beve...ient=safari&rls=en&source=lnms&sa=X&ved=0ahUKEwj9gdv16anRAhWHsVQKHTDjBDUQ_AUIBA
How many do you need? If tooled, it may [will] be easier to drill & rip a
channel flange than to source a small quantity of spec. material.
Opus
#14 ·
#15 ·
I'd weld on a piece of mild steel to the inside of the channel, then drill and tap from the other side. No need to cut any angles, just weld it on. Nothing to warp as you drill and tap after welding from the opposite side.
#20 ·
Ya I know, i was looking through my off cuts and C3x4.1 flange is the exact same size as the 1/2" bevel washers so ill just use the channel and make my own washers out of mild steel.
Sent from my LG-K210 using Tapatalk
