Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: P&H Tig
  1. #51
    Nov 2016
    Re: P&H Tig
    Quote Originally Posted by ewallace View Post
    I just came across a P&H Tig welder very cheap. The machine is AC only! Does anyone know where to find info on these welders? Can you succcesfully weld Thin mild steel on AC with a tig?
    P&H built machines for specific purposes for their customers. The "AC Only" TIG machines were probably for welding aluminum and magnesium only. (probably aircraft manufacturers) I would not recommend using it for welding steel. AC does not create the heat distribution needed. A machine with DCRP capability is what you need.
  2. #52
    Visalia, CA
    Re: P&H Tig
    i like turtles
    bosses stuff:
    trailblazer 325
    maxstar 200
    my stuff:
    sa 200
    fronius transpocket 180
    100 amp Lincoln w/f
    97 f350 DIT
    Kevin
  3. #53
    Jul 2021
    Canada
    Re: P&H Tig
    Hi I know this is an old thread and I am new to this forum so advise accordingly if I should approach posting in a better way. This post is relevant to my situation. I recently acquired an old Linde DAL 300 HFGW TIG welder which was made under licence in Toronto. It is almost identical to the P&H unit I see in photos on the internet. As I am new to this machine and to TIG welding I need some help. First does anyone have a circuit diagram for this unit. The one I have is incomplete, falling apart and hard to read.
    I had it transported from Chilliwack in BC to my place about 700km. I have removed the cover and blown the insides down. What do I need to look for before plugging it in. I plan to bury a dedicated ground Rod or can I use existing ones for my solar panels and utility supply which are bonded together close to where I am planning to place the unit. Do I need to worry about the electronics in my workshop (solar panel devices) if I have everything grounded and the gaps set according to an earlier post in this thread.
    At first glance all looks good. I can send photos.
  4. #54
    Jul 2021
    Canada
    Re: P&H Tig
  5. #55
    Jul 2021
    Canada
    Re: P&H Tig
  6. #56
    Jul 2021
    Canada
    Re: P&H Tig
  7. #57
    Jul 2021
    Canada
    Re: P&H Tig
Page generated in 1,632,505,326.90721 seconds with 12 queries
