Results 1 to 25 of 38
Thread: Welder issues - I'm stumped
    Dec 2015
    I own a Lincoln Electric Weld-Pak 140 (from Home Depot). It's my first welder and I've always had issues with it - mostly cold welds, especially with heavier gauge steel. I used nice a Miller MIG welder in my welding classes which worked amazingly well by comparison. So my buddy let me borrow his Miller 140 which I tested out in his shop with no problems. I take it home and fire it up and get the same result as my Lincoln Electric. I tried multiple AC outlets on different circuits and still couldn't lay down a proper bead. Is the power in my house not outputting enough voltage/amperage to power this thing?
    Los Angeles
    Re: Welder issues - I'm stumped
    It's possible.
    Easy to check with a Multi Meter.
    Check the voltage at the receptacle.
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Dec 2015
    It's possible.
    I tested it and it's 120V
    Jan 2014
    First state
    Are you using the same settings, and same material as you did at your friend's place?
    Check the voltage at the receptacle while under load; e.g. while welding. If there is no load on the receptacle, it will read full voltage. You may have a loose connection at the breaker, or ground buss, for that circuit.
    What gauge wire and what amperage breaker is feeding that circuit? It should be a 20A breaker and 12 ga wire. 15A and #14 wire is not good.
    PrimeWeld 225X TIG
    Millermatic 180 Mig
    Lincoln IdealArc 250
    Thermal Dynamics Cutmaster 42
    Cut50 Plasma cutter
    Craftsman(1980) buzzbox purchased new
    Dec 2015
    It's possible.
    It's actually 118.9
    Jan 2008
    Richmond, Virginia
    118.9 under load? Plug in a toaster oven, hair dryer or some such power hog and measure it under a steady load.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Dec 2015
    Quote Originally Posted by Will S. View Post
    My circuit breaker is unmarked and very old. I'm sure my issues have something to do with how it's set up. I'm using the exact same settings and on top of that, the welder is a Millermatic, so it's an it more fool proof than my Lincoln. Im afraid I am going to have to call an electrician to sort this out. Thanks for your input.
    I don't think I'm going to be able to hold the multimeter and operate the welder at the same time.
    Dec 2015
    No load. I can't hold the meter while I weld unfortunately. I do hear the welder fan slow down when I turn on a 500W light. I trip the breakers often while welding as well.
    Mar 2007
    TX
    You really shouldn't have anything else on that circuit while welding.... the welder needs all the juice it can get.
    HH 187
    Miller Bluestar1E
    AHP AlphaTig 200X
    Jan 2014
    Hallieford, VA
    You need a 20 amp circuit to run that welder. If your feed line to the outlets is #14 wire, it won't handle 20 amps, 15 amp only. If the feed wire from the panel is #12 wire, buy a 20 amp breaker, install it and don't run anything else on that circuit when you are welding. If you need lighting, run it on an extension cord from an outlet on a different circuit.
    Jerry
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Nov 2004
    Southern Montana
    How far is the outlet from the breaker panel? Are you using an extension cord between the outlet and the welder plug?
    (Also, what storeman said.)
    Dec 2015
    Maybe 30-40 feet away. I've tried with everything off. It must be inadequate wiring.
    Oct 2007
    Yuba City, CA
    Quote Originally Posted by Neophyte View Post
    And what is the wire gauge of this long extension cord?
    It's easy to get voltage drop on a skinny cord, coupled with insufficient power/voltage from the wall outlet and the welder is choked for power.
    Blackbird
    Nov 2012
    You need to test it under a load (i.e. the same conditions as when you're having trouble). Testing an unloaded circuit tells you virtually nothing. I would guess that you have under size wiring for what you're doing or a loose connection or possible a bad splice in the wiring. The next time that you have trouble, go and immediately check your breaker and the outlet and see if they're warm. They shouldn't be but if they are then there is a bad connection to it.
    Nov 2016
    USA
    Your Lincoln weld pack 140 needs to run off a at least a 20 amp circuit and if you have to use an ext/ cord 30 to 40 feet use a 10/3 ext/ cord. I speak from experience, I too had the same problem until I started using a 20 amp circuit. I upgraded to a 180.
    Good luck
    Aug 2015
    Alaska
    If you don't know electricity, you will really need an electrician to look at it. You can cause a fire if you are overloading the wiring, especially in an older house. The breaker tripping says that you are overloading the circuit. If the panel is in the area that you are welding and you have the space and capacity in the panel, it would be very cheap and easy for an electrician to install a 20a,120v or a 30a, 240v (or both) adjacent to the panel. Then you can get some heavy outdoor 3-wire electrical cord, 8/3 or 10/3 SOOW Portable Cord 600V UL/CSA, and put the appropriate ends on it to make an extension cord. I used 6 gauge and made a 40' extension cord for my 350a, 240v Lincoln and works great. Just let the electrician know you plan so he can size the house wire accordingly.
    Jun 2011
    Texas
    Is the breaker tripping?
    -Ruark
    "Become one with the puddle, grasshopper" - Welding Instructor
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    Jan 2015
    Ohio
    On page 10 of your manual it says you need a 20 amp breaker and 12/3 or larger for an extension cord which would also apply to the house wiring. And as many have said, nothing else on that circuit while welding, even with a 20 amp breaker and 12/3 wire.
    Dedicated circuit as stated. IF you are gonna upgrade wire, I would go with #10 and a 30 amp breaker and definitely no smaller than a extension cord with #10 wire too.
    Dec 2015
    It turned out the circuit was only 15amps and didn't have the proper gauge wire. I had an electrician run a dedicated 30amp line to a new outlet and the welder is working perfectly. Instead of fixing the original, cold welds, I just ran over them. I also had a 220v outlet installed as well, in case I upgrade my welder. Thanks to all for your input!
    Mar 2005
    Under a Rock
    Good call on hiring an electrician.
    How many amps is the 220v receptacle?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Dec 2015
    That power upgrade will make a world of difference.
    Jun 2016
    Back to the jungle
    Amazing how things work with proper "fuel" aint it ?.
    Call the electric dude back and get a few outlets installed for other demanding tools like a compressor, table saw, bandsaw etc.Buy yourself a real extension cord too. Stay out of Depots.
    Dec 2015
    It's on two 30amp breakers
    Mar 2005
    Under a Rock
    Huh????
    I sure hope you mean a two pole 30 amp breaker
    Hypertherm PM 45
    HTP 221
Page generated in 1,634,950,919.20043 seconds with 12 queries
