Results 26 to 38 of 38
Thread: Welder issues - I'm stumped
    Sebeka and Bemidji MN
    Re: Welder issues - I'm stumped
    Huh????
    I sure hope you mean a two pole 30 amp breaker
    Sometimes 2 breakers are used and a piece of wire goes through the hole on the switch to tie them together.
    It's a 30 amp 240v when used like that.
    Although I've only seen it used on older wiring jobs so it may not be done anymore?
    Yes if you use a tie that would be fine I guess
    Not sure if that is code anymore
    I'll stick with a dedicated two pole breaker
    Also if I was putting in a 220 outlet
    I would have made it a 50 amp
    Huh????
    It's two 30 amp breakers that aren't connected. What should I tell my electrician to install?
    Quote Originally Posted by Neophyte View Post
    Honestly you should find another electrician
    You shouldn't have to tell a professional electrician anything
    I use the dedicated breaker for my stuff too.
    He just told me that it was a double pole breaker. Is that correct?
  8. #33
    Dec 2007
    Los Angeles
    Correct.
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
  9. #34
    Correct.
    Ok thanks. I'm going to check to see if there is actually a double pole breaker there when I get home.
  10. #35
    Dec 2007
    Los Angeles
    I'm sure you did.
    They throw people for a sec because they do look like 2 single Breakers side by side and they will have 30amp stamped on each side.
    Are the 2 120v outlets your new 120v 30amp receptacles?
    Ed Conley
    MM252
    MM211 (Sold)
    SO 2020 bender
    Beer in the fridge
  11. #36
    Yes.
    What broccoli said.
    If you pop the breaker you want both 110 legs to be shut off.
    Not sure legs is the right terminology but you know what I mean.
    Here's pics
  12. #37
    Also I think Dave was right
    Looks like the only thing that separates a single pole from a 2 pole is the tie...
  13. #38
    Oct 2016
    SW Michigan
    Some are made as two pole and have one handle, some are two separate breakers with a tying mechanism between the operating levers. Don't run them as separated handles. If they are separate handles, at the very least get the proper connecting bar. Sometimes it was just a roll pin that went into the hole on the handles. You want them to both operate together. I DON'T know if that is still code, been too long. btw. Square D QO are the standard if you have the choice.
    A red Buzz Box, a Hobart MigMan, Cricket XL, Spectrum 300, and a Syncrowave 250.
    x - 330ST Aircrafter, 130XP
Page generated in 1,634,954,346.31982 seconds with 13 queries
