Results 1 to 21 of 21
Thread: Drywall router + lathe = broom handle repair awesomeness
    Morton, Washington
    So earlier this week I couldn't find a broom with a handle at the school shop. After some hunting I did manage to find one and a half dozen broken handles.
    Researching handle threads I found a hand die for cutting 3/4" wood threads but reading the reviews several mentioned the die cut 6 TPI and didn't work as expected for handles despite the claims of the description. After some measuring I opted to try 3/4" 5 TPI stub acme. Kinda odd but old threads like broom handles conform to their own standard. A few days ago I cut a 3/4" 5 TPI stub acme test plug from aluminum and the the fit was great. Unfortunately, as expected, when I tried the hss tool on the wood just splintered apart.
    Today while running some robot parts I decided to fill the time by fixing brooms. A few minutes at the table saw I was able to put my drywall router on the lathe with some zip ties. Plenty rigid for the task. I used a 1/8th inch ball nose end mill to cut the threads. Two passes and done. Easy as pie and the fit was great.
    Figured some of you might need to fix a broom or two so maybe you'd find this interesting. Enjoy!
    Big Lake/Monticello MN
    Re: Drywall router + lathe = broom handle repair awesomeness
    Funny, interesting and helpful
    Syncro 350
    Dec 2008
    North Bay, CA
    +1 Dave nailed it.
    That is awesome. Must have been at least a little bit fun!
    Oct 2016
    SW Michigan
    That's crafty. Never would have thought of that in a hundred years. Good Job.
    bo
    A red Buzz Box, a Hobart MigMan, Cricket XL, Spectrum 300, and a Syncrowave 250.
    x - 330ST Aircrafter, 130XP
    Jun 2011
    Aiken SC area
    Damn that's slick! Bob
    Apr 2011
    minnesota
    Beats grinding a taper and driving it in and running a screw with a washer like I do but I don't have a lathe or dry wall router
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
    Apr 2012
    socal
    Gotta lotta free time on your hands, huh?
    What is the sound of one knee jerking?
    Arizona
    hope you cleaned all that yucky sawdust off the lathe
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    May 2008
    Orange, TX
    Where's the dial indicator to monitor progress?
    Who keeps breaking all the broom handles?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Nov 2012
    new york city
    awesome thinking out of the box forhire. we use thousands of brooms here and put large plywood gussets on either end of the handle where it meets the broom.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Dec 2009
    Stevens Point, WI
    Nice work!
    We convert our brooms and brushes to aluminum handles, they tend to break less.
    Tube channel: https://youtube.com/@VPTfab
    Morton, Washington
    Thanks Dave.
    Quote Originally Posted by el bob View Post
    +1 Dave nailed it. That is awesome. Must have been at least a little bit fun!
    Thanks Bob. It's fun to mess around now and again. Sometimes I just do stuff because I can.
    Quote Originally Posted by boroko View Post
    Thanks.
    Quote Originally Posted by rhunt View Post
    Thanks.
    Quote Originally Posted by farmshop View Post
    Now you have reason to buy a lathe for the farmshop.
    Quote Originally Posted by cornemuse View Post
    The great thing about CNC equipment is that I have a lot of free time. I have to always be doing something. I circle the shop like a shark looking for something to fix, do, or improve. Sure I can buy broom handles down the street for $7 each but where is the fun in that.
    A little sawdust never hurt anyone. Shop gets cleaned everyday. If it's not clean when you start then you clean and then clean again when your done.
    Your funny! This was done by eye... I stopped when it looked about the same as the broken one. After I had the first one I just ran the dials to the same depth and they all came out the same.
    I broke the last one. Cheap pot-metal end. Looked at it wrong.
    Quote Originally Posted by docwelder View Post
    If anyone would appreciate this trick it would be you! I like the plywood gusset idea.
    Quote Originally Posted by VPT View Post
    Nice work! We convert our brooms and brushes to aluminum handles, they tend to break less.
    Thanks. Do you buy the aluminum handles or make them? I thought about turning some aluminum adapters but didn't have enough stock on hand. Turning the wood threads was free.
    Jan 2014
    Hallieford, VA
    I've got the same drywall cutter. I need to try that on my lathe just for fun. Thanks.
    Jerry
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Dec 2005
    Midland, Texas
    Innovation at it's finest!
    America Needs AMERICA'S Oil!!!
    "Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
    Morton, Washington
    Quote Originally Posted by storeman View Post
    Thanks Jerry. It worked remarkably well. I'm sure I'll find more uses for wood threads in the future.
    Quote Originally Posted by steve45 View Post
    You know what they say... necessity is the mother of invention.
    Jan 2008
    Richmond, Virginia
    Take this broom and stick it.
    Speaking as a former FIRST mentor, you've been hanging around those kids too long.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Nov 2012
    new york city
    forhire; although we use a different repair method i'm going to tell our machinist about your fix. that is if i can remember it 2 hours from now
    i.u.o.e. # 15
    Dec 2009
    Stevens Point, WI
    Thanks Dave.
    I make most of them. Most times I thread a short chunk to fit whatever broom, brush, dipnet, and then cut a length of tube and weld it to the threaded stub.
    McGregor, Iowa
    I like that idea, It will cut good flat bottom threads. I did something similar a long time ago by putting a saw blade in my tool post grinder and dialing down the speed. The threads weren't nice and square but they worked. I like your idea better cause they could be flat bottom or any shape you want it to be by grinding the bit to the proper angles.
    Oct 2016
    Delavan WI
    Pretty cool!
    How many passes did it take?
    Morton, Washington
    I tell them the most important tool in the shop is the broom. I'm still having fun. I don't get wrapped up in the competitive side. I keep to the shop as much as possible.
    My memory isn't what it use to be either.
    Good idea. I might make a few when the wood ones get too short.
    Quote Originally Posted by ferrret3238 View Post
    So I thought about grinding a split tool to stub acme but after looking at a few factory ends I decide a ball end mill would be close enough. I'd like to find a published standard but so far I haven't found one.
Page generated in 1,713,257,730.81217 seconds with 19 queries
