Turbotorch vs Bernz O Matic
5.9K views 3 replies 4 participants last post by  BD1
Does anyone have practical experience (or test figures) comparing heat output of the Turbotorch TX500 set (I think 504 is hotter than 503) vs Turbotorch STK-11 vs the BernzOmatic TS8000? The Turbotorch literature is confusing in that they say that the TX500 series is hoter than any other hand torch. However, I found a table which says that the STK-11 will silver braze 2" copper tubing, while the TX504 will silver braze only 1 1/4" copper tubing. I read one post that said the Bernz auto-light feature quit after only a short life.
(http://www.hvacwebconnection.com/images/151184 TurboTorch.pdf)
I had an old torch which was may father's. It was a Turbotorch Spitfire for use with MAPP. Apparently it's not made anymore. It looked similar to the current STK-9. I thought it was great, but now I see that there are a lot of improvements which have been developed.
I have nothing right now, so I'm trying to figure out what to get while reading is cheaper than trying out.
#2 ·
I have a turbotorch w/five interchangeable tips for use w/acetylene. I purchased it in the early 1980's and it's never let me down. If I were looking to replace, this what I would go after again. I've silver soldered copper line for HVAC and chillers several times up to and including 2.50" refrigerant lines.
#4 ·
