Results 1 to 18 of 18
Thread: Anybody know what this tripod is for?
    Sep 2008
    Dalton, GA
    I found this tripod at the house we bought a few years back. I just wondering what it would be used for - lifting, rigging, lowering material, or ?
    It is about 5' tall at the join. It is galvanized.
    It seems pretty heavy duty and wellmade.
    Maybe someone will recognize it.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Nov 2012
    Re: Anybody know what this tripod is for?
    The lack of bracing between the legs tells me that it's definitely NOT heavy duty. It may be strong but without some bracing to insure that the legs don't bend or fold up, I would not use it for anything heavy or anything that was I wasn't willing to take a chance on falling.
    Jun 2009
    Draper, UT
    Hold a dutch oven over a fire ?
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC
    Jan 2006
    In A Nice Comfy Chair
    Quote Originally Posted by frieed View Post
    X2
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Sep 2008
    Dalton, GA
    It definitely would work for that, but would be pretty heavy to lug to the campsite.
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
    Jan 2016
    northeast USA
    how do you know it was ment to be a tripod, looks like those clamps could also just let the pipe hang straight down, that may just be a few parts to a much larger piece of something someone built..
    Aug 2013
    Over engineered bottle rocket launcher?
    Feb 2009
    Central Illinois
    Fence corner post with braces.
    Dan D.
    Manipulator Of Metal
    Nov 2016
    USA
    Maybe blacksmithing, holding something hot.
    May 2007
    SoCal
    Quote Originally Posted by Dcraft View Post
    That'ld be one long, skinny mortar tube.
    It's what you want it for.
    Job 28:1,2
    Danny
    Apr 2010
    wb4rt
    No one carries a 'Dutch' when backpacking . . .
    X3
    If the pipe-brackets are fixed at 120 its probably a tripod.
    Opus
    Apr 2010
    Kenai, Alaska
    wb4rt, there are tripods to hold a 'soft pad' to the bilge of a sailboat that is standing on its keel- that look very similar? The boat's keel is on blocks holding 90some% of the boat's wt. This type of tripod had a rod inserted into the top of that outside tube and is adjusted to keep the boat (wine glass cross section) on and 'even keel' and upright. These tripods don't much hold wt as much as keep the boat from leaning.
    https://images.duckduckgo.com/iu/?u=...Paint3.jpg&f=1
    not sure if this is the answer? but the similarity is there.
    Cheers,
    Kevin Morin
    Kenai, AK
    Nov 2004
    Southern Montana
    It could be used to pull posts/roots when used with a come-along.
    Mar 2005
    Under a Rock
    It's for holding your Coleman gas lantern when you go Bullhead fishing at night.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Sep 2008
    Dalton, GA
    wb4rt
    X3
    Opus
    Hey Opus.
    As an Eagle Scout I know better than to backpack a cast iron Dutch oven, although I often used two aluminum pie pans to do about the same. A tinfoil reflector oven makes great biscuits too!
    I'm saying I wouldn't even lug this tripod when car camping.
    Thanks everyone for your responses. I had already considered use as a corner fence post, pulling up fence post or saplings, and picking up manholes. Your ideas about propping up a boat, cooking tripod, etc are new thoughts.
    I hope someone can come up with a good use otherwise I'm probably going to scrap it and get out of my way.
    Thanks !!
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
    Mar 2014
    Looks like kind of a cool enough thing to me that it'd be a shame just to send it to the scrap yard. If nothing else its got some "yard art" potential. You could make one of those gongs out of an old welding gas cylinder and hang in the center of it.
    Feb 2016
    Myrtle Beach
    Quote Originally Posted by Kevin Morin View Post
    Cheers,
    Kevin Morin
    Kenai, AK
    That was the first thing I thought also.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
    Jan 2008
    Richmond, Virginia
    Fence braces.
    Name:  fence braces.JPG
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
Page generated in 1,624,061,953.53885 seconds with 12 queries
