Results 1 to 14 of 14
Thread: Changing leads on a stickmate
    Feb 2014
    I'm wanting to increase lead length on my stickmate. It has 4 awg size now. How long could I run this size? Should I get 2awg? Wanting to get to 50'
    Sent from my SM-G900V using Tapatalk
    Jan 2008
    Richmond, Virginia
    Re: Changing leads on a stickmate
    Is that 50 feet total, or 50 ft ground lead and 50 foot electrode lead? I would go with 2 AWG. Pick a chart, any chart:
    Name:  welding cable ampacity from Lincoln Electric.jpg
    Name:  welding cable size chart.jpg
    Name:  welding cable amps.JPG
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Feb 2014
    That's what I needed, thanks! 2 it is.
    May 2015
    Barre Town, VT
    One thing I like to do is put quick connectors on the 2awg wire and put ~10ft of 4awg on the stinger. The 4awg is a lot lighter so it doesn't drag the stringer down as much.
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Jan 2008
    Richmond, Virginia
    Good idea on the lighter whip, especially if the existing #4 is still in good shape. If the whip gets cut or melted, no big deal.
    Inexpensive sources of cable are TEMCo (on Amazon) and Electron Beam Technologies (prices and monthly specials listed on Facebook).
    SP-175 +
    Miller spot welder
    Feb 2014
    Quote Originally Posted by Iain P View Post
    Great idea!
    Mar 2013
    You might want to consider changing your fixed leads to dinse connectors on the machine.
    Then it's easy to change the length of your leads and you can also buy pre-made whips and extensions.
    Feb 2014
    Quote Originally Posted by Pete.S. View Post
    This is the best option I have seen so far. I'm going to do this for sure. And add 1/0 main leads with a #2 whip at the end.
    Jan 2008
    Richmond, Virginia
    1/0 seems a bit overkill unless you have very long leads. 1 gauge would be easier to drag around.
    Here's some current prices from Electron Beam technologies:
    4g (23 mm sq) EBT Part No. 46-PXL...... $0.78 per foot
    2g (35 mm sq) EBT Part No. 69-PXL...... $1.13 per foot
    1g (43 mm sq) EBT Part No. 84-PXL...... $1.38 per foot
    1/0 (54 mm sq) EBT Part No. 107-PXL...... $1.75 per foot
    SP-175 +
    Miller spot welder
    Feb 2014
    I'm still waffling back and forth on what I need/want. The welder is on a cart and is fairly mobile. It would do fine as it is but longer leads would be nice. I will probably settle on 2ga 50 feet (ground and stinger combined length. Then keep the 15 ft 4 GA whip at the stinger.
    Mar 2013
    Quote Originally Posted by kendall View Post
    Sounds reasonable. I think larger than 2ga is overkill.
    I wouldn't bother with a smaller 4ga lead though. We have 2ga at work and if you buy good quality leads they are smooth and easy to work with. We have about 30 ft on both stinger and ground clamp. It also came with 4ga leads but not as good quality as the ones we have now.
    Jun 2011
    I had a job that needed longer leads on the welder, I took 25 foot number 4 cables for a Miller and clamped the ground to one end and the stinger to the other end. It worked fine, I'm sure OSHA would have a melt down.
    Jan 2014
    Sorry to dig up a 4 year old thread but this seemed like the most relevant thread I could find.
    I have a 160 amp IGBT stick welder with a 60% duty cycle. I am 100 percent a home hobbyist. If I read the chats above correctly, I am good with 4 AWG for 70FT of total lead length correct? Doesn't matter if the stinger is 50ft and ground clamp is 20ft or any other combination such as 35/35 split correct?
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by akcooper9 View Post
    Correct....total length is all that matters, not how you proportion that length.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
Page generated in 1,713,289,039.82860 seconds with 19 queries
