Results 1 to 10 of 10
Thread: SA200 heat question?
    Dec 2016
    So I recently got my SA200 welding and have noticed that when I weld I am a lot hotter than on my buzz box. What I mean is 125 amps on my SA200 feels way colder than 125amps on my buzz box. Is this normal with sa200?
    Apr 2008
    NW ON Canada
    Re: SA200 heat question?
    The sa will have a much smoother and softer arc than your buzz box. Don't pay too much attention to numbers. If you need more heat, turn it up a little.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    May 2008
    Orange, TX
    I would imagine your buzz box is an AC only machine in which case your arc characteristics are going to be a bit different than the DC of the SA200.
    Also, are the SA exciter and main brushes in good condition and both armature commutators clean? Fine Voltage control rheostat winding surface clean?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2016
    Everything is pretty clean, and my buzz box has ex. Thanks guys I will just go on how it feels
    Dec 2016
    *DC I mean
    Nov 2013
    Livingston, New Jersey, United States
    Duane how do you go about cleaning the Voltage​ rheostat winding surface. Thank you
    John
    Sent from my XT1254 using Tapatalk
    May 2008
    Orange, TX
    Fine sandpaper or Scotch-Brite on the winding surface where the wiper contacts.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Nov 2013
    Thanks I have never done that so I am going to.
    John
    Jun 2013
    Quote Originally Posted by Nathan114312 View Post
    Don't forget your 125 amps can be obtained on two different heat settings combined with the appropriate fine currant adjustment. Each will give you different arc characteristics.
    piece of soapstone
    tape measure
    chipping hammer (wire handle type)
    tip cleaners
    Southern Illinois
    I run 7018 Excalibur at around 125. On my Redface SA I usually am in 3rd gear around 50. If I want a drier puddle I go to 4th and 10-20. The fine adjustment controls volts ( heat) in the puddle. For wetter puddle turn volts up, drier puddle turn it down and selecting a higher gear (coarse adjust).
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
Page generated in 1,713,306,453.39099 seconds with 18 queries
