Results 26 to 50 of 68
Thread: L-Tec PCM-VPi but it is said
    Apr 2016
    CA
    Re: L-Tec PCM-VPi but it is said
    Brushing up on the user manual some more. From what I am understanding the Plunger is reversible too and it is the part that engages and disengages or disables the torch should the momentary switch be pushed while the torch is disassembled. The only thing I have not ordered yet is the O-Ring and the Seat.
    How often does the seat and plunger need replacing?
    Jan 2005
    Almost never..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    Apr 2016
    CA
    Good good good. So there is no reason to have more than one spare on hand in my parts kit box.
    Apr 2016
    CA
    Looking over the torch manual I see the difference between the PT31-XL and PT31XLPC is about .500 or 1/2" with the XL being the shorter at 2.250" and the XLPC being 2.750". Now here is where I am confused about the torch I got. It says PT31 XL on the torch but when I measure it and look at the images of the two torches my torch looks like a PT31-XLPC the longer torch.
    Are they basically the same torch with interchangeable parts to make them either an XL or XLPC?
    Name:  PT31XL PT31XLPC Torches.jpg
Size:  43.8 KBName:  20170326_201102.jpg
Size:  36.4 KBName:  20170329_125931.jpg
  5. #30
    Jan 2005
    When you add the long tip consumables.. There is your difference. I think it's kind of a hold over to the XL torches that take the double sided electrodes, and short tips.. Just call yours a PC and it's good to go.
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  6. #31
    Apr 2016
    CA
    Yeah I pretty much figured my torch has been configured and used as a PC. I always like to know what makes things tick just my nature I guess. In my attempts to learn and know as much about this torch as possible I am looking up as much as possible before ordering parts. I would like to know what it takes to make the torch use the XL double sided electrodes with the shorter 15/20 amp nozzles. Just learning as much as I can as fast as I can
    You never know when some NewOldStock will show up on ebay.
    Ordered the 5x 30/40amp XT performance nozzles you linked on ebay for $20.00 shipped and ordered the 35/40amp XT Spare Parts Kit 21980 from Weldingsupply.com for under $100.00 shipped. https://weldingsupply.com/cgi-bin/ei...UNDEF:OR:21980 Now I will have a factory Yellow ESAB container to keep all the consumables in " yeah baby yeah "
    Then went to my Favorite local Welding supply " California WS " and purchased two electrodes, one Heat Shield and one Swirl Ring. I tried to give them the business for all the other parts but at the end of the day I was saving over $50.00 so I had to do the on line purchase thing.
    Any way the Electrodes from my local supply did not have the Chrome plating on the Lower part of the shaft where the swirl ring goes as they were almost all copper top to bottom. Will that be a problem or cause them to not last as long?
  7. #32
    Jan 2005
    No, there are quality electrodes built both ways..With the high freq, you can get away with the cheaper China electrodes pretty well. Nothing really moves in the torch, and i never had a issue with them.. Still prefer using the USA stuff, most the time..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  8. #33
    Apr 2016
    CA
    Yeah these were made in USA ESAB parts. I pulled them out of the package my self. They were hanging on a rotating rack near the check out counter. Any way I was thinking the Chrome plating might help with longevity of the parts as the tips have the same chrome plating on them. In fact I asked the lady helping me with my purchase and she told me it must have been an original part. I shrugged it off as her not knowing what she was talking about. but also thought she might be on to something. I know such a contradiction...
    I can hardly wait until the correct nozzles arrive and I am able to start cutting things up with laser like precision. One can hope so any way.
  9. #34
    Apr 2016
    CA
    By the way, I have the adapter to mount a Victor SL-60 torch with the ATC setup to all those Esab's. Only makes sense to do on the 875-1125 machines, because you give up way too much on the 40 amps and below machines.You only gain on the bigger machines..
    Pondering what you mean by this... Are you saying that the 40amp machines can use the SL-60 torch with an adaptor or are you saying the PCM 875-1125 machines are better for using the SL-60 torch? I am confused by this statement.
    Edit: NVM I get it now it only makes sense for the SL-60 on the bigger machines 875-1125
  10. #35
    Apr 2016
    CA
    So I was working on a Receiver hitch plate to be used between a Garden Tractor and a Cherry picker and got to using the new consumables. It is not very easy to make nice clean cuts for me for some reason. Maybe it was because I was out of position squatting down while cutting IDK but My tips took a beating. I think either my technique is very poor or the settings on the machine are off or something else is going on that I am not able to figure out.
    I have been wondering about the air going into the machine. The machine has an air filter water separator thing with a regulator and I'm not sure it is working correctly. According to the user manual the Air is suppose to be adjusted to 75 psi for all cutting or is that not correct. I am not sure about the psi thing.
    Another thing is that the PSI gauge at the machine regulator reads 80 psi but when the air starts flowing the psi drops to about 60 psi. Would this cause problems? I have not been able to adjust the air so that it stays at 75 psi while air is flowing to torch.
  11. #36
    Apr 2016
    CA
    I made a best offer of $50.00 last night on ebay and the offer was accepted for an ESAB Basic plasma Circle cutting kit 0558002675
Size:  42.4 KBName:  s-l1600.jpg
  12. #37
    Jul 2016
    Midwest
    Thermal makes adapters to fit almost all plasma units. and Yes You can put an SL60 on a VPI. I might even have a few kits laying around. On the ESAB units you had to pin down the start cartridge because is a blow back torch on a HF machine. Done it many times.
  13. #38
    Jul 2016
    Midwest
    All ESAB units can use the SL60 or even SL40. The 875 and 1125 see an marked improvement in out put power. The ESAB and Hypertherm guys Hated these adaptations. lol...
  14. #39
    Jul 2016
    Midwest
    You only really need 60psi. Also note that there is or was a little window in the bottom front of the VPI that caused shutdowns. it was in case that little panel was removed and someone tried to use the machine. You often had to take a Sharpie and color in the window to fool the machine.
  15. #40
    Jan 2005
    Do not put a SL-40 torch on a High freq machine,The SL-40 torch is not rated for High freq.(does not work either) You will gain almost nothing with a SL-60 torch on your machine. Larger machines yes, but lose-lose on anything with the PT-31XT setup..You need to get the to flow @ 8O PSI while purging.. I had the 1125, so I know the consumable life sucked. Got better with the 1500 powercut,and PT-32 torch, Then the last Esab PT-37-38-39 is a fantastic torch.. I did put a SL-60 torch on a Thermal 38XL, and that doubled what that machine would cut on it's 29 amps..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  16. #41
    Apr 2016
    CA
    Ok thank you Scott. I will look into the filter/regulator combo to see if I can do anything to increase the flow psi.
  17. #42
    Jan 2005
    It's showing 75 psi for XT consumables.. All my PT-31 machines wanted 80 psi. (380.500i, Powercut 650,but the125,250 used less psi with the short consumables) With the high freq setup, no blowing the arc out like the blow-back torch styles.. Old school still have a few things going for it.. No moving torch parts,and the smallest torch head there is. Right now wish I never sold the Handy-plasma 380. Esab fixed that machine over time..(Italian)
    http://www.esab.ca/literature/plasma...i_f-15-228.pdf
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  18. #43
    Apr 2016
    CA
    Yeah I was under the same impression of using 75 psi from the same manual. I read that thing twice and I get the 75 psi from what I have circled in the following illustration. I do notice how it says at least 75 psi.
  19. #44
    Apr 2016
    CA
    I made some more cuts this evening on thin gauge sheet for an engine plate and frame for the front suspension of a Scott's lawn tractor he he he. Using a 1.5" x 1.5" angle iron with two edges facing down and middle facing up I was able to make some really nice cuts with the 35/40 21008 nozzles.
  20. #45
    Jan 2005
    Start using the trigger lock, because it will help you relax from holding the button down. Works real well with that setup..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  21. #46
    Apr 2016
    CA
    I cut 5/8" solid round with ease. I am learning to angle the nozzle away until the cutting is established and to not drag the nozzle on thicker gauge material. I will try the trigger lock. Not really making long enough cuts to worry about it yet. I had that aha moment earlier when cutting the engine plate.
  22. #47
    Jul 2016
    Midwest
    My mistake on the SL42. I only considered the back end of the torch, Not the front. The SL60 does have an adaptor and it will work by pinning the start cartridge. Is it a cost effective switch over? No Way. The adapter is $30. the torch is $550. You can buy several OEM style PT's for 1/2 of that.
  23. #48
    Apr 2016
    CA
    I saw an sl60 in local CL for $200 but have no use for it.
  24. #49
    Jan 2005
    Just one of adapters for Esab work on almost all of the older machines. I have the Esab adapter for the 1125 on down, and the ATC machine end,Sl-60 ATC torch.. Used you can get the RTP torch, and forgo the ATC setup. About $300.00 on Ebay total, new /old stock.. It could be worth it for the right guy,machine.. Some machines do not seem to need the pin bushing, and others do. Best order one anyway.
    The SL-40 torch would be a good one for the smaller Esab machines, but not in the cards..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  25. #50
    Apr 2016
    CA
    Ooops I goofed the torch on CL was actually a SL-40 https://merced.craigslist.org/tls/6028838846.html
Page generated in 1,713,283,646.85911 seconds with 19 queries
