Results 1 to 17 of 17
Thread: Rail Anvil Stand
    May 2007
    SoCal
    Rail Anvil Stand
    This is my most recent pic from last night. I cleaned up the bottom of the legs and replaced the temporary brace for some hammered square rod. I added the leg boosters because I felt myself leaning over without them. I still need a forge, and a place for it would be awesome, so... ... we'll see.
    Job 28:1,2
    Danny
    Arizona
    Re: Rail Anvil Stand
    Looks sweet. I have a piece of track waiting to be turned into an anvil
    Sent from my SM-T350 using Tapatalk
    If the women don't find you handsome, they should at least find you handy.
    May 2007
    SoCal
    Nice! Good luck with that.
    Job 28:1,2
    Danny
    Nice, good idea having the single leg at anvil horn.
    Nov 2012
    new york city
    awesome stand and anvil. it looks very sturdy.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Feb 2009
    Coastal NC
    Nice work.
    Feb 2016
    East Texas
    Does the anvil ring more from hits now, sense the stand is metal? It looks awesome!
    Forney C5 Arc Welder
    Lincoln Idealarc 250-250 Ac/Dc Arc Welder
    Miller Bobcat 225g Plus
    Lincoln PowerMig 200
    Forney O/A Rig
    Mar 2005
    Under a Rock
    Quote Originally Posted by Jess View Post
    I was wondering the same thing...
    coulda filled the legs with sand and welded em up....
    but it looks heavy enough as is...
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    May 2010
    Ct.
    Looks good.
    How did you make the square hole?
    Is hole called a hardee or something like that?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    May 2007
    SoCal
    Actually, I haven't used it yet. I don't know if I'll need to quiet it down or not, but that will sort itself out. I can always drill holes at the top of the legs for oil and sand. I might add some mudflap rubber between them and see what that does. Lots of other projects need attention as well. I still need a forge.
    Oh, the hardy hole was made by drilling 5 pilot holes @ 1/8" diameter and then stepping up the center hole to 1/2". After that it was just a matter of using the Dremel and a carbide cutter to get it close enough. You can see after drilling and before the Dremel how the hole came about here.
    Job 28:1,2
    Danny
    Aug 2012
    AR
    Quote Originally Posted by jpump5 View Post
    Looks good.
    The square hole in an anvil is called a "hardie hole". The bottom tool that fits in the hole is call the "hardie", an upright bladed tool for cutting off hot steel. Spelling is either "hardie" or "hardy", but I believe the "ie" is the proper spelling. Other bottom tools that fit into the hardie hole that have other functions besides cutting are called hardie tools.
    Nov 2015
    Northford, Connecticut
    Awsome!....How many hours do you have invested in this project and are the triangular gussets added in or were part of the RR track before you started? I have RR track candidates but don't those gussets like yours. Chris
    May 2007
    SoCal
    No, the gussets, or buttresses were not there, I added them last. This rail is small gauge, like a cart rail from a mine or something. And it was retired a bit wonky to one side. I figured more is more. I did the same for the H beam that is under it to lend some rigidity.
    Hours? Not sure.
    Job 28:1,2
    Danny
    Mar 2015
    And the British call the cutoff tools for the hardy hole "butchers". Because that is exactly what they can do to your fingers if you try using your anvil with it in the hardie hole.
    Aug 2012
    AR
    Quote Originally Posted by bent View Post
    Also, a distinction on this side of the pond. The hardies (cut off) over here generally have a double bevel and the butchers have one bevel, one straight side. YES!! Make it a habit of taking the hardie out of the anvil as soon as you finish using it!
    Nov 2016
    USA
    Awesome looking stand, looks to be stout as a bull.
    Oct 2008
    Pearland, TX
    I've been eyeballing rail anvils for the last couple of weeks (after being prompted by a guy here at work), and I have to say your anvil is by far the cleanest one I've seen to date, love it! Can you share any details on how you made it? Looks like the top is ground/milled flat?
    Nevermind, found your youtube video!
Page generated in 1,713,264,977.13311 seconds with 18 queries
