Hi Mcm308, I ended up putting a Bernard q200 on mine. I really wanted a Lincoln Pro Curve 250 but couldn't find a discount deal, I have a Pro Curve 300 on my TA210 and really like it. The Bernard is pretty close to the Lincoln.
What MIG guns are you guys using on your 211? What's a good upgrade? Thanks
Thermal Arc 210 - Tweco 211I - Cutmaster 52
The 211i uses a standard tweco, Lincoln back end, I did have to cut and splice the trigger wire plug from the original gun, the 211i has a similar 2 wire twist connect to the machine, but are smaller pins than the Lincoln connector. I put a 2 wire trailer like connector on the machine plug and on the Bernard and Pro Curve guns so I can use either gun on both machines.
