Results 1 to 9 of 9
Thread: Hypertherm 45xp vs. Miller Spectrum 625
    Dec 2015
    Napa, CA
    The miller will be outfitted with 20' leads plus the $100 rebate brings total to $1720
    The hypertherm unit w/o cpc and same length leads is $1775
    Which unit would you guys recomend all things considered.
    Im coming from a Hobart 27 amp unit and wanted to cut 3/16 and 1/8th faster.
    Also in the running is the poor man's 625, the Hobart airforce 40i.
    Cheers!
    Miller XMT 350 CC/CV
    Miller S74-D
    Hobart Airforce 500i
    Delaware
    Re: Hypertherm 45xp vs. Miller Spectrum 625
    Hypertherm hands down, Miller/Hobart are not as good as they used to be.
    Jun 2015
    Alaska born, Alaska bred
    I'd wager that between Hypertherm, Thermal Dynamics, Miller, and Lincoln, Hypertherm owns 90% of the market. There's a reason.
    2000 Lincoln SA-250
    1974 Miller Dial-Arc 250
    Oct 2011
    Hamlin, NY
    Miller is good, but the Hypertherm is BEST.
    I only have a small Miller 375 Extreme because I got it new for half price... and you can see I'm a die hard blue fan...
    Ryan
    CK WF1 TIG wire feeder
    Miller Spectrum 375 Xtreme
    Optrel e684
    Miller Digital Elite
    Miller Weld-Mask
    Dec 2015
    Napa, CA
    The only problem I see with the 45XP is that it can't run on 120v.
    A major advantage to the 625 and 40i are the dual voltage capabilities for mobility...
    Miller S74-D
    Jun 2015
    On 120v power, the Miller has a duty cycle of 20% at 27A. That's pretty weak.
    Unless your plan is to take the plasma cutter in to somebody's garage and run it off of their Home Depot special pancake compressor, then mobility with the Hypertherm won't be a problem. If you're operating off of a service truck, with a generator and an engine driven air compressor, then 230v is fine because probably every generator you can buy today provides 230v power.
    If you're working in a shop, well, a shop that doesn't have 230v power won't be in business very long. Even kitchens in restaurants have 230v power.
    2000 Lincoln SA-250
    Jun 2016
    Back to the jungle
    I had a Spectrum. Excellent machine. I got into the table thing so bought a 45 pre XPand sold the Spectrum. Now I find myself needing a 110 rig more often than planned. 30XP air. ASAP. Whats another couple grand when we're having fun,........
    Hillbilly all the 110 machines are 20% So is the 30air but 35% with the 220 connected
    Dec 2015
    Napa, CA
    I bit the bullet and invested in the Hypertherm. Im pretty excited! Will update when it arrives.
    Best.
    Miller S74-D
    I say wise investment and all I have are Millers
Page generated in 1,634,641,406.80981 seconds with 10 queries
