Hello everyone,
I recently picked up a hobart handler 135 without a gun and got a gun for it. When welding the machine "stutters" and doesn't produce anything I'd even call a weld it more or less just sprays globs of metal on the plate. The output voltage while welding on setting 4 is 12-15 volts the manual says it should be around 22 volts. So I suspect this is the problem with it. So has anyone here had this problem and is it worth fixing?
Thanks for the help.
