Results 1 to 18 of 18
Thread: Double gate latch ideas
    Oct 2005
    Montrose, CO
    I have a customer that we build a set of double gates for to secure a commercial lot. There will be a cane pole to steady the gate when their closed. However, I need to design a multi-point latch system that holds the gate secure even if someone lifts the cane. Does anyone have any design ideas/pictures for a slick system like this? Thanks
    Dynamic Metalworks
    Montrose, CO
    DynMetalworks.com
    Los Angeles
    Re: Double gate latch ideas
    How does it lock currently?
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Upstate NY
    Unless both posts are contained 360 degrees, once the cane is pulled any latch is useless.
    Normally, a chain is wrapped around the two posts, secured by a lock.
    Keep in mind that "sufficient force to render the gates non-functional" is 1 sedan at 40mph. Security is relative.
    Welders:
    2008 Lincoln 140 GMAW&FCAW
    2012 HF 165 'toy' GTAW&SMAW
    1970's Cobbled together O/A
    Los Angeles
    MM211 (Sold)
    Los Angeles
    MM211 (Sold)
    Mar 2016
    Minneapolis MN
    might give you an idea
    Name:  gate latch.jpg
    Ct
    I would do a drop bar but sideways, like a heavy duty slide bolt. This would actually hold the gates somewhat together if the drop bar was lifted, especially if you used 3/4 round.
    Use a couple sections of 3/4 sch40 pipe the solid round will slide nicely inside,
    Soda springs,Id
    I designed and built this for my double gate. It would be easy to add a padlock to it. This gate faces a sometimes harsh west wind and has survived 4 years so far.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  9. Likes VaughnT liked this post
  10. #9
    Oct 2005
    Montrose, CO
    Thanks for the ideas. I'll post pics when done.
    Dynamic Metalworks
    Montrose, CO
    DynMetalworks.com
  11. #10
    Apr 2010
    BryanDowdy
    Quote Originally Posted by BryanDowdy View Post
    Depending upon: the size, weight, and build of the gates - you can
    have great fun with truck/trailer hardware.
    http://austinhardware.com/camandbarlocks.aspx
    Check-out all three windows . . .
    Off the shelf components, easy to build, secure, easy to use, and
    can be made to look really good.
    Opus
  12. #11
    Sep 2005
    Cave Creek AZ
    How about a sliding gate lock?
  13. #12
    May 2021
    Thanks for ides? I will use one of them for our gates
  14. #13
    Apr 2021
    I also love the bolts. They are very reliable. From the one side, it protects perfectly, and from the other, they look concise and cannot be played very beautifully. At the same time, I notice that we often forget to lock on it our gates. That's why I consider that it is better to have several systems o lock like https://www.howtobecomealocksmith.or...roof-padlocks/. In the afternoon, when someone at home, we lock the bolt. But for a night or when we leave and to the regular lock too. Unfortunately, we live in a troubled area, and we should take care of our safety.
  15. #14
    Nov 2019
    A lot depends on how often the gate needs to be opened and closed.
    Also take into consideration whether or not the gate will ever have an automatic opener.
    You could make the cane bolt lockable. Maybe even a cane bold on both gates. And a latch near the top of the gate to keep it from flexing too much when the cane bolts are locked.
    I've built a couple gates with a pedestrian gate to one side. It allows people through the gate and latching hardware is easy in that case.
    You can keep the main gate closed except when vehicles need to go through.
    If there is room, a sliding gate doesn't have the "cane bolt problem" Also simplifies adding an automatic opener -- you only need one instead of two openers.
    Ktech
  16. #15
    May 2007
    [QUOTE=ktech;8813724]
    yep, i did what i think ur talkin, and very simple. the horiz leg of the " angle iron" latch that pivots on one gate, blocks the thick long/tall canes from being lifted when vert leg is locked locked down in mating gates slot . when latch is opened/swiveld up, canes no longer blocked from being lifted . ill look if i got pics
  17. #16
    Try this type
    https://weldingweb.com/vbb/threads/7...41#post8813775
  18. #17
    Apr 2021
    Quote Originally Posted by DvdsVansy View Post
    I’ve heard something about these guys.Is this the cheapest option that we can find around?
  19. #18
    Jun 2011
    Texas
    You also might try this approach. To make it more secure, you could put heavy pipe in the ground for the rods to do down into. You could devise a padlock apparatus at the top so they couldn't be lifted up, if that's wanted.
    You can see it starting at about 12:00
    -Ruark
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
Page generated in 1,624,039,473.62961 seconds with 13 queries
