Results 1 to 6 of 6
Thread: S/S caster risers
    NW New Jersey
    S/S caster risers
    Need to lift a conveyor up 5 inches. 304 stainless 1/4" plate, 2"x 3/16" square tube. 3/32" red tungsten. gas lens #8 cup, synchrowave 180SD with air cooled torch. 1/16" and 3/32" 308 filler rod. Thought about doing it with the MIG machine, but the miller was set up for stainless already.Even though the material is pretty thick, I got more warpage than I expected. It won't be a problem in this application. Only needed 4 assemblies, by the time I got it dialed in, I was done.Name:  DSCF0568.jpg
Size:  34.0 KBName:  DSCF0569.jpg
Size:  37.1 KBName:  DSCF0563.jpg
Size:  26.2 KB Parts conveyor that it goes on is all stainless with plastic table top belt with cleats.
    Apr 2010
    Re: S/S caster risers
    albrightree
    Heavy S/S is a different animal - get used to it - and study to compensate.
    . . . by the time I got it dialed in, I was done.
    ^ ^ ^ for not over/over-welding . . .
    Opus
    Feb 2009
    Coastal NC
    They look good, nice work.
    Lay out, clamp, tack and weld. Remove clamps after it cools down and you should have little to no movement.
    NW New Jersey
    Thanks, I spent far more time cutting and drilling than I did welding. It wasn't a huge amount of warpage, each side warped upward less than 1/32" . Just surprised, I probably over sized the material, but it was what we had in the shop. I weld more stainless in the 11ga to 20ga range, and kind of expect it. Here's the first one installed, sorry about the phone camera picture quality.Name:  0430171039.jpg
    Mar 2006
    Yuma, Arizona
    I think you made some ankle biters. Round those off for me, please. Because I am always the guy that gets bitten.
    Lincoln Power Mig 210MP MIG
    Lincoln TIG 300-300
    Lincoln Hobby-Weld 110v Thanks JLAMES
    My brain
    NW New Jersey
    Went into shop to use bench grinder(don't have a belt sander), and found wheel has new profile. This is what happens when you leave the shop door open. Made radius to match caster. Caster feet always seem to be a trip hazard. Shouldn't be too bad, conveyor is positioned under packaging machine. Hope to finish today, conveyor has been sitting on top of a plastic pallet(temporarily) for 2 months.Name:  DSCF0574.jpg
Size:  28.8 KBName:  DSCF0576.jpg
Page generated in 1,624,550,804.08086 seconds with 12 queries
