Results 1 to 15 of 15
Thread: What are these
    Los Angeles
    What are these
    Are these old Redhead holders?
    Powder actuated tools?
    Anyone have an idea of age?Name:  image.png
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Los Angeles
    Re: What are these
    Bueller?
    MM211 (Sold)
    CT
    Re: What are these
    I am going to guess part of a toggle fastener of some kind.
    Miller Multimatic 255
    Mar 2016
    Minneapolis MN
    Re: What are these
    elecric fence doo hikies
    Mar 2015
    Milwaukee, WI
    Re: What are these
    They were used on old electric hammers (percussive only - no rotation) using A-taper and B-taper chisels. To drill holes in concrete you used star bits and you had to rotate the bit by hand while the electric hammer pounded away.
    Jun 2008
    Re: What are these
    As he said https://tinyurl.com/y94vrsgc and they were a pia if you didn't turn them enough and they got locked in the hole when you were drilling. You had to be careful not to to drill too close to the edge or you'd bust out a good sized chunk. They held tho, better than a lot of fasteners of the day ...........Mike
    Re: What are these
    That red device holds what was called a self drilling anchor for a specific threaded rod size. The end of anchor has teeth on it and as the hammer was driving to would rotate the handle making the hole . Once hole was drilled the anchor was removed from hole and a red wedge insert was stuck in the tip of the anchor. You then placed anchor still inside the holder with the wedge into the drilled hole and activate gun. The pounding would then '' SET '' the anchor into the concrete . Upon completion the end of shell in the gun was snapped off leaving the anchor flush with concrete. The ORIGINAL was called '' REDHEAD ''. I found this on ebay. The RED wedge actually goes INTO the end with the teeth after drilling.
    I think that gun was a black and decker 5015.
    Los Angeles
    Re: What are these
    Thank you fellas.
    MM211 (Sold)
    Jan 2008
    Richmond, Virginia
    Re: What are these
    Here ya go ...
    Name:  self drilling anchor.JPG
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Los Angeles
    Re: What are these
    age of the Electric drills used?
    MM211 (Sold)
    Dec 2015
    Western New York State, USA
    Re: What are these
    ive use air hammer drill that used those. drilling into ceiling was hard work as you had to push up fairly hard all the time. since hilti drills became popular and they sell air and electric versions i stopped using the old fashioned concrete anchors. hilti drills only require a light pressure when drilling
    Jan 2008
    Richmond, Virginia
    Re: What are these
    The Red Head self-drilling anchor was invented in 1910.
    SP-175 +
    Miller spot welder
    Feb 2012
    Re: What are these
    Quote Originally Posted by WNY_TomB View Post
    Hilti guns are even faster. The ones I've installed get tested to hold 180 lbs.
    Feb 2017
    Re: What are these
    Got boxes of those and lead style anchors here. Star drills, yeeech that there is rougher work than rastlin a single speed 1/4hp 1/2" electric drill. Hilti still good imo
    Ramsets are the most fun though
    Apr 2016
    Cleveland, Ohio
    Re: What are these
    Looks like someone solved your problem, but I wanted to let you know that each month my company does a contest on its Facebook page called "Guess What it is." We give away a prize to the winner. I also tell people if they ever run across something they don't know what it is, post it on our Facebook page and ask. We have thousands of manufacturers, engineers, machinists, welders, makers who are followers. They love to go at that kind of stuff.
    Gina M. Tabasso
    HGR Industrial Surplus
    gtabasso@hgrinc.com
    www.hgrinc.com
Page generated in 1,713,287,958.06862 seconds with 19 queries
