Results 1 to 2 of 2
Thread: Hobart Handler 120
    Sep 2008
    Dalton, GA
    Hobart Handler 120
    I bought a nice little Hobart Handler 120 for $50 on CL. I figured there must be a problem, but it works fine. It is set up for fluxcore and will be handy for small jobs outside or away from my shop. It has a working gas solenoid so I can run as MIG too. I dug out a spare regulator and hose from my stash.
    I bought the Piecemaker 14 conversion kit from USAWeld and what a great improvement in the wire feeding. That is a worthwhile upgrade and now I can use the same tips and nozzle as my MM211. They deserve an Ďatta boy for that kit!
    Iím planning to build a cart for it with 10Ē tires so it will roll outside easily. It will almost be like a handtruck with front casters to roll on the shop floor but be able to break it onto the larger tires for outside. Iím deciding on whether to have a space for a 120 tank or not. Not sure if thatís a good idea.
    Also bought a nice 7Ē Baldor bench grinder from the same guy. It is in nearly new condition including the factory stand.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Dec 2011
    New Hampshire
    Re: Hobart Handler 120
    You should buy a lottery ticket asap, couple nice finds there.
Page generated in 1,624,065,395.58188 seconds with 11 queries
