Results 1 to 9 of 9
Thread: ?? pipe detail/print - help ??
    May 2007
    I don't know what this detail is, or about, hoping some of you do, and can explain.
    May 2007
    Re: ?? pipe detail/print - help ??
    well, it turned out, it was a weep ring w/ #7 rebar, 1/4" flare bevel
    Apr 2008
    NW ON Canada
    Ya. It's simple weld detail symbols there. Nothing real complicated.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    May 2007
    Quote Originally Posted by snoeproe View Post
    i wish u'd come along before, as the 168 others and myself couldnt figure it out
    Mar 2014
    I don't see where any 1/4" flare bevel welds are being called for on that drawing. I do see some 5/8" ones though.
    May 2007
    i'm not sure what those 5/8 flare groove pertained to. I think theres some error in that print. the inspector did some math, or trig or something (that i didnt understand) , that gives you the percentage of throat of flare bevel weld on each side (which rounded off to 1/4" ) , based off the radius of the #7 rebar and the formula. So i ran some stringers for a hefty 1/4", being its hard to measure. I welded together a template, that I was told they'd use as a guide to bore holes. I didn't really understand what, was all going on, i just kept my mouth shut, and nodded yes when i was talked to, and did what i was told, and left.
    Big Lake/Monticello MN
    It looks a mess to me... I'd have needed to see the part to figure out what it all meant for sure.
    ...And probably still ask to make sure I understand.
    Syncro 350
    May 2007
    a mess, thats an understatement. the iron workers had caged it in w/ rebar, suitable to hold a gorilla in alcatraz. it took me 6 hrs w/ a mirror and bending rod, being as flexible w/ my body as a snake to do the bottom three, the top three were a lil better.
    That's outside of my skills for sure
    Plus, I'm about as flexible as a dump truck is agile.
    Syncro 350
Page generated in 1,713,256,442.56828 seconds with 19 queries
