Results 1 to 5 of 5
Thread: Power Cool W400?
    Apr 2018
    Power Cool W400?
    Anyone know the dimensions of this unit? Looks like it might be intended to mount under a welder. I've got a 255EXT and am going to buy a water cooler; be nice if the W400 would fit under it.
    Nov 2008
    Re: Power Cool W400?
    It will, but you will find that the cooler is a bit oversized for the unit. It is designed to nest under the larger units, such as the 350EXT.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Mar 2017
    Forest Grove OR
    I have the 350 EXT and use the smaller W300, it has been fine. The W400 wasn't available at the time. I've run my 20 water cooled torch at 260 amps and the torch never gets hot. The W300 is plenty of cooler for the job, though I'm happy so see they offer a bigger unit now, which I would have gotten if it were available last year.
    Everlast 350 EXT - Thermal Dynamics Cutmaster 52 - Rogue Fabrication M600 xHD tube bender
    Milwaukee 4208 Mag Drill - Shopmaster Eldorado Combo mill/lathe machine with DRO.
    Theresa, NY...Thats almost Canada!
    Dimensions are roughly 30"L x 11"W x 10.5"H. The height is taking into account the feet and top stacking rails.
    Apr 2018
    Seems to stack up just fine. (Had to move around the top and bottom standoffs though.)
Page generated in 1,621,260,345.24769 seconds with 12 queries
