Results 51 to 75 of 99
Thread: Update to my welder Harbor Freight 170
  1. #51
    Re: Update to my welder Harbor Freight 170
    I just took the wire from the board relay to transformer and use power the new relay.
    Then from off on switch add a new wire for new power supply for transformer to new relay then out to transformer.
    I also have a duty cycle chart for welder on this post 📫
    PS If not clear I will redo this post later.
    Quote Originally Posted by poolbizz View Post
    Dave can you do a step by step of how to do the relay?. Thanks
  2. #52
    Jan 2009
    Quote Originally Posted by xmmancharl View Post
    used that modded hf mig 180 many years back... worked quite well
    did not like the wire feeder mechanism
    Charl, its good to see you show up in this thread. I've gotten some good use out of the MIG-180. Again, thanks!
    As for the wire feed, yes, its marginal especially considering the upgraded longer stinger length. HF apparently sized the feed motor just-good-enough for the shorter original stinger.
    I use Flux Core exclusively (outdoor welding area). The feed wheel tension needed, was gouging the FC wire making it difficult to feed. I got a new feed wheel with better teeth and that generally evened out the feed speed. But it still wants the stinger laid out in a straight line to feed smoothly.
    Here's the most recent thing I've welded with it, a hitch adapter. Power sufficient to dig into the 1.25" hitch bar. I've used this adapter several times now including bottoming it hard (without the cargo carrier attached), coming out of a gas station. The adapter is solid.
    * Amico MIG-130A Flux, Dual Voltage. Truly portable!
    * HF MIG-180 with all the mods. Heavy.
    * Grizzly H8153 Stick/Tig 130/160.
    * Wards PowrKraft AC-230. Stick & carbon arc.
  3. Likes xmmancharl liked this post
  4. #53
    Jun 2018
    Dave , what I see is you ran a red wire from the com port on the board relay to the left side of new relay and another red wire from the N.O. port of board relay to the right side of new relay. The black wire goes from left side of new relay to where.Also the wire from transformer was plugged in where? also the black wire that's now connected to new relay on left side was connected where? Pictures...
    I also have a duty cycle chart for welder on this post ��
    PS I'd nor clear I will redo this post later.
  5. #54
    I have thinking of getting a longer gun.
    I found the gun to 10 feet. Witch great for some type of work and putting a external 30 pound roll.
    But most work today is bench type welding and 10 pounds is almost same as 30 pound roll cost per pound.
    Dave , what I see is you ran a red wire from the com port on the board relay to the left side of new relay and another red wire from the N.O. port of board relay to the right side of new relay. The black wire goes from left side of new relay to where. Picture...
  6. #55
    Jun 2018
    Dave, So I asked you to show in detail how to do relay.... And this is the response; your thinking of getting a longer gun.... Forget the relay , I'll take whatever your smoking...
  7. #56
    Mar 2005
    Under a Rock
    You are beating a dead horse trying to get anything useful out of smithdoor.
    Check out any of the other 900 threads that he posts on daily.
    A good percentage of the members here are basically fed up with his babbling / incoherent nonsense.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  8. #57
    I think you are just joking, but just in case you’re serious……please don’t.
  9. #58
    Jun 2018
    Serious about what? please don't? Who S@it n your corn flakes....
    I know you are just joking, but just in case you’re serious……please don’t.
  10. #59
    *smoking
  11. #60
    Jun 2018
    smoking what....
    *smoking
  12. #61
    Read your own post re: smoking
    On second thought never mind
  13. #62
    Jun 2018
    I'll drink to that ...
  14. #63
    Mar 2005
    Under a Rock
    Well that took a weird turn.
    But poolbiz .... I think lis was referring to "smoking whatever Smith is smoking"
    And I agree, Whatever he is smoking I wouldn't touch it with a 10 foot pole
    Hypertherm PM 45
    HTP 221
  15. #64
    Jun 2018
  16. #65
    I aways look at how built and see there a week point.
    My equipment had to work ever time.
    There are some here that buy a welder like cell phone and do not care. They also well read the ads and youtube and believe all the data. I do testing to find out
    For your information I have never smoke any thing.
  17. #66
    Big Lake/Monticello MN
    Just a reminder, he has had a brain injury of some type - does the best he can I imagine.
    Syncro 350
  18. Likes Lis2323, California, CAVEMANN liked this post
  19. #67
    Mar 2005
    Under a Rock
    Just a reminder, he has had a brain injury of some type .
    I suspected that was the case.
    Probably cooked his brain through chemo and/or radiation.
    While I have empathy for his situation,
    It is still not an excuse to allow him to infiltrate the board on a daily basis with bad information and constant nonsensical arguments.
    A lot of new welders come to this board seeking quality information and advice.
    Smithdoor routinely pisses all over that opportunity.
    I believe it's the moderator/administrators Job to take care of the situation.
    By your own admission he has brain damage.
    So why is a person who is obviously not in the right state of mind allowed to continue in this fashion?
    If it was just John T complaining, I could see the hesitation
    But it's not.
    Many have complained about his actions and disregard for simple reasoning.
    Hypertherm PM 45
    HTP 221
  20. #68
    You can see the different in the two relays in photos.
    My experience is from being welding close to 60 years. Still see same mistakes that I made back in 1960's on YouTube.
    When I started on very large shops had MIG.
    Tig was a dream for most do to cost. Fuxcore is still being played with and limited to large plates.
    I have been on off chemo since 2009 with stage 4 colon cancer.
    Also had scaffolding brake 18 feet off ground.
    Attachment 1741436
    [QUOTE=poolbizz;8872175]Attachment 1741395Attachment 1741396
  21. #69
    Jun 2018
    Dave if you can take a picture of where the black wire connects to On/Off switch , Then the wire from transformer where was that connected so that I know where it was I would appreciate it.Dave my BAD yesterday , CANCER SUCKS HOPEFULLY YOU HAVE IT BY THE BALLS ... [QUOTE=smithdoor;8872767]You can see the different in the two relays in photos.
    Attachment 1741436
  22. Likes California liked this post
  23. #70
    Jan 2009
    This amateur has learned a lot from Smithdoor, that explains the design considerations behind the extensive mods I found in the HF welder I bought used. The diagrams and their explanation earlier in this thread are one example of what I'm talking about.
  24. Likes Lis2323 liked this post
  25. #71
    Mar 2005
    Under a Rock
    Quote Originally Posted by California View Post
    3% of useful does not cancel out 97% of garbage.
    Hypertherm PM 45
    HTP 221
  26. #72
    Feel free to not read his posts.
    Empathy, or ignoring, will both work the same.
    Syncro 350
  27. Likes Lis2323, California liked this post
  28. #73
    Here a close up photos.
    The 1 Orange typing shows a brown wire from switch to relay contact.
    The 2 light red. Typing shows the brown and white wire from relay contact (brown) to Transformer (white).
    Dave if you can take a picture of where the black wire connects to On/Off switch , Then the wire from transformer where was that connected so that I know where it was I would appreciate it.Dave my BAD yesterday , CANCER SUCKS HOPEFULLY YOU HAVE IT BY THE BALLS ... on YouTube.
  29. Likes California liked this post
  30. #74
    My relay was 120 volt coil I had shelf and did the way dryers use 120v used the ground for 120 volts. This not to code but saved money on a new relay.
    If look photo you see a [GREEN] wire going to coil. The other side coil is coming from the old relay use as pilot relay
  31. #75
    Mar 2005
    Under a Rock
    So in essence you are saying, ignore the entire board.
    Whatever, I've said my peace.
    But the fact is your diplomatic approach isn't helping anything and will eventually drive away more knowledgeable people from this forum.
    But you are the cat Wrangler.
    And so it shall be.
    peace out
    Hypertherm PM 45
    HTP 221
Page generated in 1,713,264,980.16319 seconds with 20 queries
