View Poll Results: Which machine would you choose (and why)?
Voters
12. You may not vote on this poll
  • Hypertherm Powermax30 AIR
    6 50.00%
  • Hypertherm Powermax30 XP
    4 33.33%
  • Lincoln Tomahawk 625
    0 0%
  • Thermal Dynamics Cutmaster 60i
    2 16.67%
  • Miller Spectrum 375 X-treme
    0 0%
Results 1 to 25 of 26
Thread: New Plasma Machine - Help Me Choose
    Apr 2011
    Dirty Coast
    I'm trying to decide on a new plasma machine. I have a giant old transformer powered Thermal Dynamics from about 25 years ago. It's a beast, but too cumbersome to move around and it is becoming unreliable. So I'm looking for a new machine.
    Some points to consider:
    1) Majority of my work is 1/4" or less mild and stainless steel with the occasional 3/8". Rarely would I need to cut 1/2" or more. (I have oxy-acetlyne as well)
    2) I like the idea of dual-voltage (120V - 240V).
    3) Having an on-board air compressor would simply setup and increase portability.
    4) Max budget is set to about ~$1,800, so the table below reflects that. Of course it never hurts to spend less.
    Looking at these options below, what do you all think?
    Thanks in advance for your suggestions and thoughts.
    Name:  Plasma Cutters.JPG
    Name:  Plasma Cutters 2.JPG
    Jul 2016
    Midwest
    Re: New Plasma Machine - Help Me Choose
    Consider warranty as well. I had a Top brand that blew up at 3 years and 3 months. If it had been a different brand it would have been covered instead of scraped.
    Oct 2007
    New Hampshire, North Carolina
    The Powermax30XP has more power (load voltage, wattage output) as compared to The T-D 42, and is made in USA . This unit runs on 120 or 240, comes with easy power adapters and a case. It will do everything you want, but like all dual voltage units has relatively slow speeds when you get into 3/8" and thicker. Think of what you will be using this for in the future....and for some extra money consider going with the Powermax45XP (230 only), with the ability to cut 5/8" on a production basis, sever double that and with no issues with duty cycle on the thicker stuff.. The 45XP can also be used with a machine torch and has an optional CPC machine interface that allows easy connection to cnc machines, track burners, pipe cutters, etc. The 45XP is the most popular plasma cutter on the planet with over 26,000 in the field in less than two years of production, made in USA by emloyees of Hypertherm that actually own the company! Jim Colt
    Note: your voting poll indicates that the Hypertherm units are Thermal Dynamics! Steer clear of the imported Tomahawk units....very low duty cycle and short consumable life.
    You DO NOT need a poll to know. HYPERTHERM is the one and only if funds permit. Your poll could be on the MODEL and not manufacture. The 45XP as stated is the most popular. When they first hit the market , local supplier sold out fast.
    Hypertherm would be the best quality. Razor cut 45 with the hypertherm style torch would be another good option at less than 1/2 the price. As far as I know both have 3 year warranty.
    Apr 2011
    Dirty Coast
    Thank you for the advice, Jim. I really appreciate it. For once in my life I am trying to be realistic and not overbuy. I can definitely understand the greater capability of that Powermax45XP, but I’m just not convinced I’m going to need that at this stage. If I ever move onto a CNC table, then I can see myself getting a dedicated 45 or 60 amp unit from Hypertherm. Based on the work I’ve been doing for the last few years, I never really get into the heavy stuff. I guess I need to think about it some more.
    Thanks for pointing out my screw up on the poll. Is there a moderator here that can make those changes? My ability to edit has disappeared from this thread.
    Thanks everyone else as well for your opinions. I really value the input.
    Apr 2011
    Dirty Coast
    That’s interesting. Never looked into those before. Looks like it’s a two year warranty with an extra six months if you register online.
    http://www.razorweld.com/catalogue_p...ubcategory=87#
    Feb 2015
    Cutmaster 42 hit every point you listed except OBC. Seems like a clear winner, not in your poll though. I did own one and good units, plus it will save you some cash.
    Jul 2006
    Texas
    Quote Originally Posted by Lindley View Post
    Done.
    Mar 2017
    Forest Grove OR
    I have a cutmaster 52 that is near the same specs at the cutmaster 60I, but comes in consistently under $1400. I've seen in the $1250 range a few times. I cut 3/8 with it all the time which is only half it's rated power, quick and clean. It's small and easy to move, probably only 30 pounds. They all use the same consumables, so no chance of having problems buying stuff years from now.
    Everlast 350 EXT - Thermal Dynamics Cutmaster 52 - Rogue Fabrication M600 xHD tube bender
    Milwaukee 4208 Mag Drill - Shopmaster Eldorado Combo mill/lathe machine with DRO.
    Jan 2016
    northeast USA
    hypertherm 45 and dont look back..................
    Feb 2009
    Chicago
    It's 3 year warranty on the power source. I can get you one if you want. It's a great little plasma but it's only 220v.
    I also love my hypertherm 45. Again 220v only.
    If you need the 110v option I say the hypertherm 30xp is a damn good machine. I had one for a little while.
    If I could get whatever I wanted at the moment I'd get the 30air. Just something about plugging it in and cutting and being done. Not having to deal with an air hose or waiting for the compressor to build up pressure. Just plug in, cut and put away and only deal with 1 input.
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Carbide3d Nomad3
    Sherline 4400 CNC Lathe
    May 2010
    Sparks, NV
    [QUOTE=Lindley;8610734]That’s interesting. Never looked into those before. Looks like it’s a two year warranty with an extra six months if you register online.
    45 amps x 96v =4320 cutting watts. Watts is what you want to look at for cutting ability. If you want to understand this concept more, ask Jim Colt
    Apr 2011
    Dirty Coast
    [QUOTE=soutthpaw;8610801]
    Makes sense. Power = Amperage X Volts (P = IV)
    I'm a red blooded American same as most on here and generally believe more power is always better.
    But I'm liking this idea too:
    Quote Originally Posted by Gamble View Post
    Mobility and ease of use with the on-board compressor are hard to ignore. I may hold off on buying a big boy until I move onto a dedicated CNC plasma setup.
    May 2010
    Sparks, NV
    Hypertherm operate at a high voltage so you get more cut per amp composted to many import machines
    Apr 2011
    Dirty Coast
    Using Hypertherm's specs from their website:
    Powermax30 AIR: 83 volts x 30 amps = 2,490 Watts
    Powermax30: 125 volts x 30 amps = 3,750 Watts
    Pwermax45 XP: 145 volts x 45 amps = 6,525 Watts
    https://www.hypertherm.com/en-US/hyp...owermax30-air/
    https://www.hypertherm.com/en-US/hyp...powermax30-xp/
    https://www.hypertherm.com/en-US/hyp...powermax45-xp/
    Jan 2005
    Cutmaster 42 = 3840
    Cutmaster 60i = 7560
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    Feb 2009
    Chicago
    Razorcut 45 = 4320
    Esab ET220i
    Razorweld 195 Mig
    Carbide3d Nomad3
    Mar 2017
    Forest Grove OR
    Cutmaster 52 = 6,240 watts
    It's the most comparable to the Hypertherm Powermax 45xp.
    Jan 2005
    No the 60i is.. Since Thermal uses a 15+ year old torch design the 45XP is step up in cutting power.. How do I know? Have a 45XP,65 and have had many Thermals. like a 42/52/82/A-120 etc-etc.All on a cnc table, so you can tell exactly the cut speed and all the other things..
    Razor cut might be fine, but 4 year Warranty, and option of using 120/240 volts, and a SL-40,and SL-60 torch.. 40 amp gouging setup too.(SL-60)
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
    Jan 2005
    St. Johns, Michigan
    Hypertherm gets my vote...
    Pete
    ESAB SVI300
    ESAB MIG 4 HD
    MILLER PASSPORT 180
    MILLER DYNASTY 300DX
    MILLER COOLMATE 4
    MILLER 30A
    MILLER SPECTRUM 2050
    C&K WF-3
    PrimeWeld Tig 225X
    Dec 2015
    Kentucky
    I have two words as to why to spring for hypertherm JIM COLT he is on several groups and will answer any question about plasma. I've never seen a rep from any of the other company's offer the help Jim does.
    Everyone wants to save money, but cheaper ain't always better.
    I'm a firm believer we should all buy American when we can, as far as I know hypertherm is employ owned, maybe one of those employs will buy something some of us make as long as they have a job, doubt if wing sang long in China will drop by our shops
    Mike
    Jan 2005
    Quote Originally Posted by Mick120 View Post
    What Ky farmer said X2 ^^^^^^^
    Yes, but shouldn't you be buying au made stuff. Since this ia all about flag waving home boy stuff.
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
    Nov 2014
    60i. Longer warranty, higher wattage, and you can spend the extra $300 on consumables.
    Fabricator 252i
    FP120
    Cutmaster 42
    Victor torches
    Dec 2014
    Upstate NY
    Hypertherm for the win, stay away from imported chinese crap
Page generated in 1,713,292,379.27962 seconds with 20 queries
