Results 1 to 25 of 32
Thread: Welding baffles in oil pan
    Im welding some steel baffles in my steel oil pan. I will be using TIG. I have 3/32 ER70S6 or 1/16 ER309L.
    I will sand the paint off the surfaces where I will weld, but they are ledges in the pan and I cant easily clean the paint off the underside. That seems like it will be a problem.
    Any advice on properly prepping and on which filler to use? (I also have some 0.030 ER70S6 MIG wire I could twist into a filler, or I could buy some 1/16 if necessary.)
    Here is a picture of the baffles set in place:
    Here is the pan without the baffles:
    Jun 2017
    AJO, ARIZONA
    Re: Welding baffles in oil pan
    You are asking for trouble, that "paint" is actually a teflon like product, once you disturb the bond it will continue to come off plugging the oil pick up and possibly frying the engine. I saw a guy put some sort of desludger in his 7.3 POWERSTROKE, it delaminated the coating and plugged the oil pickup, the ONLY thing that saved the motor was the fact that it needed low pressure oil to feed the high pressure pump, so it wouldn't start after a short time, but they replaced it anyway for other reasons.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety. BENJAMIN FRANKLIN
    Ive never heard of an issue with people doing this to Honda pans. Its a pretty common procedure from what I gather.
    Quote Originally Posted by jwmelvin View Post
    I’ve never heard of an issue with people doing this to Honda pans. It’s a pretty common procedure from what I gather.
    Why not just tack it (or braze it) in a half a dozen places other than in the corners where it's hard to remove the paint? It's not like it needs to hold up the world.
    Syncrowave 250DX
    Miller 330 A/BP
    Miller Big Blue 251D
    Jan 2006
    In A Nice Comfy Chair
    Exactly.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    I considered that. I do know a person who had brazed baffles let go on track with catastrophic results. Is that a condemnation of all brazed baffles? Not necessarily, but it is something.
    Either way there would be paint on the backside of the metal Im attaching to. If thats not such a big concern, I guess Im okay.
    Oct 2016
    countryside of NY
    Just wondering,, why welding a baffle in tank????
    MM215, soon to be ex miller
    Victor torch set
    Lincoln ranger 10000 plus
    Quote Originally Posted by irish View Post
    It helps control the oil sloshing around around turns. This car is used with track-only tires for driving on racing circuits.
    Jan 2016
    northeast USA
    why dont you just sand or bead blast the entire inside of the pan to eliminate all the hassles and possibility of paint or coating coming undone while under use and clogging screens or oil passages?
    That's a good idea but the problem is the shelves in the pan, which will prevent cleaning or painting some areas, unless stripping by a chemical process and painting by dipping. I'm going to say this project hasn't risen to that level.
    That must have been some HEAVY (like a ton per gallon) and/or HOT (like 1400F) oil ... and/or some TIGHT (like 1000-G) turns!
    ...either that, or a botched braze job.
    Why do you need to weld in the corners in the first place? The more you weld on this thing, the more it's going to distort.
    Feb 2012
    Use the drain plug to hold the baffles in place or drill a new hole to attach the baffles. Seems like a PITA to try to weld or braze with coating.
    These were my thoughts too; brazing seems pretty good for this. I may still do it. I have Si-Bronze and Al-Bronze filler rod; which would be better (Al- rod is stronger, right?)
    I don't need to weld in the corners, I just want to secure the baffle.
    Heres a picture of where I would like to weld/braze; red shows attachment tabs to pan, which should be easy to clean, and yellow shows where I just want to prevent oil coming out, so probably brazing is good there:
    Here are examples of others having done this. I was just hoping for some execution advice from people who know welding.
    Welded 1
    Welded 2
    Welded 3
    Welded 4
    Brazed 1
    Jan 2016
    northeast USA
    a good blaster will be able to get under those shelves to get most of that coating off and shouldnt take that long, and no reason to repaint, most oil pans in the last 60 years were bare steel on the inside, I have heard the idea of painting the inside of blocks so the oil flows better back down to the pan as its a more slippery surface than the bare block, but also the down side of the paint or coating coming off and causing bigger problems, Its a personal decision on that point to paint or not..same as braze or weld..
    Good points thanks. I've been thinking there's little reason to repaint other than the outside of the pan. I'll think about trying to blast it.
    Mar 2017
    Forest Grove OR
    Pop rivets. Sorry, but welding isn't always the best answer. Just overlap the existing shelf where surfaces are flat with the new baffle.
    Everlast 350 EXT - Thermal Dynamics Cutmaster 52 - Rogue Fabrication M600 xHD tube bender
    Milwaukee 4208 Mag Drill - Shopmaster Eldorado Combo mill/lathe machine with DRO.
    Baffles are cheap insurance for an engine that is going to be raced.
    If it were me I'd get all of that coating off (either sand blast or chemical) and spot weld it in various spots.
    Feb 2012
    Quote Originally Posted by Chad86tsi View Post
    I was thinking steel pop rivets after seeing the red circles where it attaches. He could weld the rivets on the outside to prevent leaks with Er70s. Dont know why he would use ER309L. Seems like 309 would brake to easy.
    Dont know why he would ask about ER309L. Seems like 309 would brake to easy.
    Only my own ignorance, because I have 1/6" in that material. Should I get 1/16" ER70S2/6?
    Feb 2012
    I believe Er70 is good for 70,000 lbs/ square inch. Dont think it needs to be that strong but the 309 has more tendency to crack in my limited experience. I do think rivets would eliminate problems the pros mentioned above tho and you can still weld on the outside without the mentioned problems. You could braze with SiCu SilBronze instead of 309. The SiCu would hold up better than 309 for that application on a race car in my opinion but ER70 would my choice.
    EDIT: maybee somebody will correct my ignorance but I would just use your 0.030 ER70 if you decide to weld rivets from outside of the pan. Weld or braze would help prevent leaks at the rivets IMO.
    Feb 2015
    What about just making your own oil pan with baffles built in? Or you could cut the bottom off the pan, glass bead paint off weld in baffles then weld bottom of pan back on?
    2 Hobart MIG welders, 1 on the gas 1 flux core
    HTP Invertig 221 DV
    Eastwood TIG200
    HTP MIG 2400
    May 2012
    I've done a couple of minor oil pan repairs that held up, but never welded in any baffles. I read that the stamping process leaves oil pans with a lot of locked-in stresses that can cause problems when baffles have been added. Anyone seen this? Maybe any pan that has been on a car for a while has been thermo-cycled and vibrated enough to work out some of those locked-in stresses . . .
    Jun 2016
    Back to the jungle
    Quote Originally Posted by old jupiter View Post
    Yeah. I have. I used to whack the bottom out of SBC pans and make them deeper. I always brazed them.Like anything else stamped, its under tension. I never bothered adding a band. I cut the pan off and made a new "box" to attach to it.
    I asked for more details from my friend who had a failure, and it turns out it was a baffle made from 0.060" aluminum that failed in his engine. So it wasn't brazed, and seems to have failed from poor design.
    I'm leaning towards brazing or riveting and brazing.
Page generated in 1,632,586,536.78030 seconds with 11 queries
