Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Thread: Central Support Staircase
    Sep 2014
    On Saturday I cut the 4" x 4" x 1/2" wall steel square tube to the right angle and also got the cut off that creates the right angle to make the jig to hold the tread plates at the right angle. I cut out, ground and welded on the top mounting plate too. On Sunday I finished the jig and started welding on treads. So far it seems sturdy and is coming out nicely.
    I am TIG welding it.
    Sincerely,
    William McCormick
    Bilbao, Spain
    Re: Central Support Staircase
    Looking good!
    Some purist will tell you that there is some undercut in the close up of the bead in the third picture (far right) but I am not a purist and I doubt I could do any better.
    Mar 2014
    William,
    Looks hell for stout. Curious as to why you went with TIG instead of stick or dual shield (if available) though.
    Sep 2014
    Quote Originally Posted by HT2-4956 View Post
    William,
    It is going to be visible, and I am better with TIG, I do not get to do too much stick anymore. Also, the smoke is a problem where I am doing it. I wasn't sure about welding with stick, and trying to weld between the treads but looking at it, if I started at the bottom and worked my way up I could have pushed a 7018 and achieved decent results. But then there is spatter and what not. And I am sure the welds I did will hold for their intended purpose.
    When I am done, I am going to fill the 4" x 4" tube with cement, to stop any vibrations and make them really strong and solid.
    I am going to use commercial wooden beams 3" x 12"'s as treads and then polyurethane them. I am going to route the plates into the treads.
    Sincerely,
    William McCormick
    Sep 2014
    Quote Originally Posted by Mikel_24 View Post
    Looking good!
    When you come around that corner of the plate that meats the tube right at that radius, it tends to undercut, it washes some of the material into the puddle. I was still learning the weld I am more mindful now. Plus I am moving along at a decent pace.
    Only the underside of the stairs can be seen. I am just heading back from a second call or I would have worked on it more.
    Sincerely,
    William McCormick
    Bilbao, Spain
    Don't forget to take pictures of that process! I am curious to see how the routing goes.
    Is this staircase going to have any kind of railing or something?
    Sep 2014
    I picked up the lumber and surprisingly it was $200 with tax. I finished welding on the plates today, with the new hydraulic table we picked up from a friend of mine a machinist that is retiring. He has a crazy ARC welder he wants $100 for, it might come in handy.
    Sincerely,
    William McCormick
    Sep 2014
    Anyone know anything about this welder?
    Sincerely,
    William McCormick
    Sebeka and Bemidji MN
    Sincerely,
    William McCormick
    It's cool enough to be an end table in my living room
    Syncro 350
    Aug 2008
    I can see why you're using TIG. Close quarters with a lot of nooks and crannies that could harbor sparks, and start a fire.
    You figgerin' on Ms. Piggy using those stairs? Stout enough to even hold that fatazz Rush Limbaugh..........with a bag full of Viagra pills to boot Scumbag.
    lookin' good
    http://www.farmersamm.com/
    Jul 2014
    Please pick up that dam shovel,it just bothers me laying on the floor like that!!!
    May 2018
    Land of the Toxic Avenger
    Quote Originally Posted by gxbxc View Post
    And here I am wondering and worrying about welding next to a huge gas meter
    That stair looks heavy. Any idea how much it weighs?
    T man.
    15 + years working for myself, and by golly, I still don't know what I want to do when I grow up.
    Jul 2014
    I wonder how in the heel he is going to get it out of there,I don't see a door,and that fat azz limbaugh would not fit down those stairs.
    and now I have to look for the gas meter! I though that was at a different shop.
    Jun 2014
    Southern Illinois
    The welder is a K.O. Lee company. "knock out" model welder. I saw one sell like that at an auction one time. Weighs about as much as a bank vault. I'm sure it's a very well built welder with a good arc. The best part is it looks neat! Great for a man cave
    Steve
    Miller Dialarc 250 (1990)
    Miller Maxstar 140 STR (2003)
    Lincoln MP210 (2015)
    Victor and MECO torches
    Jun 2014
    Southern Illinois
    Found a image of faceplate. They are a rare bird for sure
    Steve
    Sep 2014
    And now I have to look for the gas meter! I thought that was at a different shop.
    The wood that gets mounted to the steel tread plates overhangs the metal tread plates by about eight inches. I believe the width at the top of the stairs is 42 inches wide. At the bottom, it gets a little wider.
    The gas meter is in my friend's machine shop.
    Sincerely,
    William McCormick
    Sep 2014
    Quote Originally Posted by T man View Post
    The stairs weigh about 800 without the wood. I just rolled the hydraulic table and stairs to one of the three roll-up gates and put a dolly in the van lowered the table and pushed the stairs into the van myself. At my son's house, I had a friend I work with meet my son and I on Mothers day morning to help us get it out of the truck and into to the house through the doorway. IBEW Local 3 boys are strong. It took five minutes, and we had it inside on two dollies. We are going to fill the tube with cement and core drill the floor one night this week.
    Yea I would not put it next to the gas meter myself though.
    Sincerely,
    William McCormick
    May 2018
    Can't wait to see it in place. Looks like a fun job, indeed.
    Thanks for sharing.
    T man.
    Jun 2010
    northern cal.
    What are they doing with all the old commercial washers or dryers?
    Lincoln Power MIG 180.
    Winco 6000 watt generator (13hp Honda)
    Sep 2014
    Quote Originally Posted by deafman View Post
    Parts. The tubs are worth almost $700 each.
    Sincerely,
    William McCormick
    Sep 2014
    Quote Originally Posted by Sparkie1957 View Post
    Thank You very much. I was wondering what kind of power it neded. I think I am going to pass on it though, especially if it is heavy. I am going to pick up a little inverter unit.
    Sincerely,
    William McCormick
    Jun 2014
    Southern Illinois
    I wish I was close. That would be a good addition to my collection. Iím sure it would weld nice for a AC machine.
    Steve
    Sep 2014
    My son and I installed the stairs today, now we can start on the wooden treads. It went pretty well a lot of putting them in place lifting and fitting then removing and coring and then notching the header and then cementing it in place. All and all very rewarding.
    Sincerely,
    William McCormick
    Sep 2014
    These are a few more pictures.
    Sincerely,
    William McCormick
    Sep 2014
    That is the finale step, we cemented it in place.
    Sincerely,
    Willliam McCormick
Page generated in 1,627,398,258.15436 seconds with 12 queries
