Results 1 to 12 of 12
Thread: Mig Liners
    Jun 2017
    AJO, ARIZONA
    Mig Liners
    I am wanting to buy an extra liner and a teflon or nylon liner for my rig The connector at the welder is euro style, are there different styles for different setups or are they interchangeable?
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    GOD HELP AMERICA!
    ďFreedom is never more than one generation away from extinction.
    We didnít pass it to our children in the bloodstream".
    RONALD REAGAN
    city of Four Flags
    Re: Mig Liners
    Usually brand specific.
    Bilbao, Spain
    Re: Mig Liners
    Mmmmm... I wodn't go as far as to say that they are brand specific. Euro is Euro everywhere.... At least, i have purchased some liners (for 0,6mm steel and 1,0mm teflon for aluminum... and I didn't have to worry about brands at all. At least in MY side of the pond.
    city of Four Flags
    Re: Mig Liners
    Ok, try putting a Binzel liner in a Tweco gun.
    Both can be Euro back ends but itís doubtful itís going to work well.
    Brand specific.
    Jun 2017
    AJO, ARIZONA
    Re: Mig Liners
    So I'm guessing that the difference will be with the lug on the end that goes into the machine. How do I tell the difference?
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    city of Four Flags
    Re: Mig Liners
    What gun do you have?
    Google search it.
    Boom, there you are
    Jun 2017
    AJO, ARIZONA
    Re: Mig Liners
    Ok, ty.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    Jun 2016
    Back to the jungle
    Re: Mig Liners
    What you do is grab the picture taker(might need them) and brand/model and ccaall USA weld (htp) and tell them you need some liners.Ask for Diana. If she isn't there, call back later.
    Jeff doesn't pick up the phone very often
    AH. I need to order some wire and tips tomorrow(today---lol)
    800 872 9353
    Jun 2017
    AJO, ARIZONA
    Re: Mig Liners
    Thanks Bonzoo, I think I have it figured out, gonna drop the gun at the machine and take a look at the liner there.
    IMPEACH BIDEN!
    NRA LIFE MEMBER
    GOD HELP AMERICA!
    RONALD REAGAN
    Mar 2017
    Re: Mig Liners
    I believe the liners are interchangable, My local welding shop supplies liner directly from the roll in any length and inside diameter, that would be a hard thing to do if every torch manufacturer uses it's own proprietary liner.
    In that case the LWS would have to stock several rolls for every brand of torch and wire diameter combination, something that is not doable for a smallish shop IMHO.
    I kno for a fact Binzel, Weldkar, Fronius and Lorch are interchangable, as I have had (either through my work or my own welders) used the generic LWS liners from the roll on all those brands.
    Re: Mig Liners
    Quote Originally Posted by Dutch Welder View Post
    They sell them off the roll because they also have the ends to go on them. Some torch assemblies will take bulk and that end is removable or just different setup than crimped on end that threads in.
    The liner material itself is all very similar. Spiral would spring steel tubing.
    The reason some are specific is some have a brass piece that is crimped permanently on the liner. Those are the pieces that make the liner specific to fit only the certain brands that use the same type.
    This is a Miller/Hobart style.
    Mar 2017
    Re: Mig Liners
    On all my mig torches (being 2 aircooled, a watercooled and a watercooled push puller, all Binzel brand ) there is nothing connected to the liner.
    I cut the liner at a bit longer then the right length, the euro connector end has a cap which one screws off, then you insert the liner as far as it will go in, cut flush and replace the nut on the euro connector end.
    But all my torches are Binzel brand, I do not have welding machine branded torches (like Miller/Esab or Lincoln)
Page generated in 1,624,060,913.41909 seconds with 11 queries
