Results 1 to 5 of 5
Thread: He / Ar premix for Aluminum TIG?
    Nov 2013
    I know there's been lots of discussion on "blending" your own from 2 tanks to give higher heat on thicker Alum. BUT,,, I have several tanks and though of just getting a mix of He/Ar in one of them.
    As I look on-line for info on what would be best all I find is talk of TriMix for SS and they contain some sm quantity of Co2. Not sure if that's appropriate for Tig Aluminum.
    Anybody know what is?
    city of Four Flags
    Re: He / Ar premix for Aluminum TIG?
    Helium based trimix is for MIGing stainless.
    TIG does not like carbon dioxide.
    Jun 2016
    SE Saskatchewan, Canada
    I have a bottle of 75% Ar /25% He for thicker sections of aluminum. To be honest I have yet to put it to use yet.
    Did some experiments with a 65% Ar/ 35% He a while ago, I think this might be the bottle I will go with next time. Makes a 200 amp machine able to weld 3/8" thick joints.
    Red Seal Journeyman Welder (2003), Red Seal Journeyman Metal Fabricator (2018), Welding Engineering Technologist (2005)
    Pressure - ASME Section IX
    Structural - CSA W47.1, CSA W47.2
    Transport tanker - CSA B620
    Aerospace - AWS D17.1
    New Zealand
    ask at the gas suppliers.
    this side of the world they have a range of He/Ar mixtures. i would expect you guys to have it also.
    i think the lowest mix i can get is 30% helium called alushield light.
    Nov 2013
    OK, so here's why not to do this....
    I went with one of my 300cui tanks for straight Argon and said "can you get me a 75/25 mix with He?". They said sure, we have it at our other depot, you can just go pick it up there now. I was geiitn' excited I then ask, "How much is it going to be?"
    At Hocon Gas;
    a 300 of Ar is $85.00
    a 300 of He is $300
    So, in my head, I'm thinking they take out $20 of Ar and add $75 of He, how much could it be?
    The answer is, they take out 25% of the Ar and add that $75 of He and come up with $275.00!!! (25 bucks less than getting a full load of He)
    So if I want to do this I'm going to have to Blend (just have to find a smaller tank, all mine are 300's). The up-side of the trip was that, when I bought straight Ar, they took my 300 in and gave me a 330
Page generated in 1,665,088,058.70863 seconds with 11 queries
