Results 1 to 14 of 14
Thread: ?? rebar to plate detail - help ??
    May 2007
    Anyone know how to determine what size flare bevel weld this is supposed to be, and/or what the formula is for figuring it. It's a #7 rebar (.875 dia). to plate.
    In the notes, it says, * = 0.40 "S" Reinforcing Bar Radius.
    May 2007
    Re: ?? rebar to plate detail - help ??
    Having problems posting the pic of print/detail - give me some time, check back please. HAVING NO LUCK, I DID IT BEFORE, DOESNT SEEM TO WORK. when i hit upload file, it doesnt seem to work
    May 2007
    Name:  2018-05-25 11.28.55.jpg
    Big Lake/Monticello MN
    I read it as 0.40 times 1/2 the diameter (also called the radius).
    Apr 2010
    123weld
    Having problems posting the pic of print/detail . . .
    Kudos - 'for staying with it' - until a postable image . . .
    I read it as 0.40 times 1/2 the diameter.
    I agree - but . . .
    On most key boards - Command + [key stroke] will magnify your screen.
    A careful examination of the extension lines - reveals a discontinuity, 'of
    where' -
    0.40 times 1/2 the diameter- is placed.
    In my observation - the specifications - and the shaded illustration of the
    weld-bead [extension lines] - are not in agreement.
    I'm going to sit on the side lines - until the Spec. Team clarifies . . .
    Opus
    May 2007
    Dave may very well be right. last time i did something for these guys, it was told to put a quarter inch weld on #7 rebar to plate, but i never saw the print/detail for it. And Daves theory comes out to just under that. As for lines, I think there just trying to make it clear to start and stop measuring throat b/t two shortest legs/points, as it must be measured diff than a fillet. I think I buy Dave answer. Kinda wonder what "S" means?
    Northern Cal., Shasta County
    "S" = size in inches??
    Apr 2010
    123weld
    This is not absolute - but the 'S' notation is legitimate . . .
    http://www.therangerstation.com/Maga...ng_symbols.htm
    Opus
    Apr 2008
    NW ON Canada
    There are 2 different S indications in the weld detail. The s on the left indicates the depth of the groove. The s on the right indicates the required depth of the weld.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    May 2018
    Land of the Toxic Avenger
    So, on a 1" diameter bar, the depth of the weld in the groove would be .20 of an inch.
    1" x .50 = .50 "
    .50" X .40 = .20"
    Your #7 rebar being ,875 of an inch would be .175" depth into the groove
    .875" X .5 = .4375"
    .4375" X .40 = .175" or slightly smaller than. 3/16 " (.1875)
    No?
    T man.
    May 2007
    sounds like everyone who answered this thread is right/helpful to me. yes, its actually smaller than 3/16, i didnt know, i was just roughing it in my head when i thought quarter. more likely inspector knew it, but was pushing me for the extra (just the way he's been). thank you everyone
    Apr 2010
    123weld
    Much - has been made of the print/weld - cross-section/and where . . .
    Advancing the conversation - what is the length of the splice-bars [weld length] ?
    In response to T man math postulation . . .
    Quote Originally Posted by T man View Post
    So . . .
    1" x .50 = .50 "
    .50" X .40 = .20"
    #7 rebar being - 875 of an inch would be .175" depth into -
    .875" X .5 = .4375"
    Weld Joint design is simple - this math analysis is redundant, inapplicable, and
    ='s [AKA] crap welding understanding . . .
    123weld
    I have welded 100's of re-bar splices - and have overseered thousands more . . .
    Weld reality - 'fill the pocket/to the top' - and your weld-inspector will be happy.
    Opus
    May 2018
    Quote Originally Posted by OPUS FERRO View Post
    123weld
    123weld
    Opus
    Makes you feel more like a man to belittle others attempts at helping when asked? Regardless of "weld reality", he posed a question, and some people here actually helped him understand , without having to act like a condescending, pompous as$
    T man.
    Mar 2014
    As an inspector...if I'd of seen a nice smooth fill up to the top of the rebar (or just a touch less in places) I'd have had no problem signing off on it as long as the weld was of the required length (per print).
Page generated in 1,713,241,626.94504 seconds with 21 queries
