Results 1 to 3 of 3
Thread: Sa250 murphy switch
    Dec 2014
    sw minnesota
    Sa250 murphy switch
    Well got to the job site today and when tried to start my sa250 with perkins diesel I noticed smoke from under the hood.
    I then took the hood off and the white wire from the start button to the amp gauge got burned off.
    I disconnected the wire but now it won't start murphy switch doesn't click or do anything so my question is can I just get rid of the Murphy switch completely without any other issues?
    Dec 2014
    sw minnesota
    Re: Sa250 murphy switch
    The serial number is a890360 if that helps with anything
    Mar 2014
    NH
    The short answer that you want to heard is: Yes. But it is there for a reason- it protects your engine. Case in point; I was running my dozer when I blew a head gasket- I knew it looking out over the hood seeing coolant blow out through the radiator... now think about you under a hood upwind of your Perkins. You aren't going see or smell anything and at some point that Perkins will stop perking if it suffers the same fate. Spend a couple of hundred to have a mechanic diagnosis the cause of the burnt wire and weld with the confidence that you will be less likely to toast the engine,
    Thunderbolt AC/DC
    330AB/P + Bernard cooler
    Syncrowave 250
    Oxy/Ace torch
    Dayton 160 MIG
    6CF pot with 185 compressor
    Too much big equipment
    Even more small tools
Page generated in 1,713,240,937.47193 seconds with 18 queries
