Results 1 to 13 of 13
Thread: TIG welding anodized aluminum
    Jun 2018
    Any advise for welding 3/32” anodized 6061 lap joint to another piece of same spec.. Would you attempt without sanding through anodized surface? Thanks very much
    Nov 2014
    PDX PNW
    Re: TIG welding anodized aluminum
    Welcome to the forum steve
    New Zealand
    look up "bump welding".
    Feb 2009
    Coastal NC
    Welcome aboard Steve
    If you wanted to sand the very beginning of your weld to break through the anodized you could and it should run smooth after.
    Dec 2015
    Southeast,Florida
    When possible I clear the anodizing from the weld area with non woven discs.Use the finest grain and there is a very small amount of scratches visible after painting weld with silver paint.
    Name:  1non woven disc2.jpg
Size:  23.8 KBName:  1non woven discs.jpg
    I'd have to be weird,To grow me a beard,Just to see what the rednecks would do
    Quote Originally Posted by tweake View Post
    +1 That's the way I've done it.
    Not sure, but I've heard sanding (especially with alum oxide paper) can embed the abrasive in the alum and cause contamination...
    Oct 2009
    Austin TX
    I will agree that sanding doesn't seem to help with the welding of anodized... or maybe I didn't sand deep enough.
    Miller Syncrowave 350
    Millermatic 252/ 30A spoolgun
    Miller Bobcat 225g w/ 3545 spoolgun
    Lincoln PowerArc4000
    Lincoln 175 Mig
    Lincoln 135 Mig
    Everlast 250EX Tig
    Century ac/dc 230 amp stick
    Victor O/A
    Hypertherm 1000 plasma
    Nov 2014
    PDX PNW
    How did the weld turn out on that tiggatoo?
    Dec 2015
    Southeast,Florida
    Pretty good,let the puddle wander too far into a few of the unbrushed areas Sorry I don't have a pic of finished weld.
    I think this method works well for thin material,it lessens the heat effects a bump technique creates under the adjoining area.
    Dec 2015
    Southeast,Florida
    I also carefully wire brush the area cleaned with the non woven pads. Non wovens don't leave much embedded contaminates ,but even the finest can ,especially in soft material like aluminum.
    Mar 2017
    No sanding or painting.
    Sent from my SCH-I545 using Tapatalk
    Tampa, Florida
    I’ve got a bunch of thin walled aluminum tubing that I scrapped from a couple of walkers, and a shower chair. The finish is very matte, I think it’s hard anodized, is there a difference between Hard anodized, and “regular” anodized aluminum? I’m trying to determine if I should keep it or not.
    I think it may be too thin for the bump weld technique, I kept it thinking that I could sand the finish off, however I’ve gotten contamination issues with the flap wheel, and the material is already pretty thin. It’s just scrap for practice, so if there’s an effective solution to removing the anodization, I’d love to hear it. I don’t need to preserve any of the properties of the anodization.
    I’ll have to look for those wheels that look like scotch-brite, I would’ve never guessed that they being plastic could remove something as hard as aluminum oxide.
    -Mark Smith
    Miller Bobcat 250
    Vulcan ProTig200
    Vulcan MigMax215
    Everlast PowerArc 210STL
    Hypertherm PowerMax45 Xp
    Feb 2009
    Coastal NC
    Nicely done Warren.
    You don't have to grind, brush or whatever you want to call it to break through any anodized to begin with.
    The old shop I used to work at, we'd run 245 to 260 and just roll with it. That was all on schedule 40 anodized pipe. The manager wants to bump and I'd just roll traditionally. Its all in what method you prefer to do.
    Look up martin marine design to see the most perfect anodized welding around, period.
Page generated in 1,713,304,289.70838 seconds with 19 queries
