Results 1 to 7 of 7
Thread: Key ring
    Oct 2013
    Key ring
    I needed a key ring for my knife. I used 1/8 mild steel welding rod and bent it in a small circle. I welded it with a Lincoln 140 MIG welder using the lowest wire feed and lowest voltage. I could only tack weld it on several sides. I ground it smooth and this is the result. It holds well enough for a key ring. Any suggestions on a better technique?
    May 2010
    Port Orchard, WA.
    Re: Key ring
    Next time use a Tig welder.
    Dont pay any attention to me
    Im just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sep 2015
    SE Pa
    Re: Key ring
    Or braze it
    Feb 2015
    North Sewickley Pa. Shop in Monaca
    Re: Key ring
    A key ring ........really...... Next guys will want to be showing " coat hangars " they made........
    May 2010
    Sparks, NV
    Re: Key ring
    You don't make coat hangers, you weld with them.
    Re: Key ring
    But only on OTR trailers and NASA projects.
    Mar 2008
    Georgetown, Texas
    Re: Key ring
    Quote Originally Posted by SmoothOperator View Post
    Now that you mention it, I made this for an interior decorator years ago to display an antique dress on. They wanted one with just a touch of class.
Page generated in 1,642,664,147.31406 seconds with 12 queries
