Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Aluminum T Joint Tig Help Needed...
    Aug 2018
    Atlanta
    Re: Aluminum T Joint Tig Help Needed...
    Howdy Motolife313, I repair Cast aluminum valve bodies on occasion, and as with all welding procedures that the Company I work for requires me to use, I have to use a gas lens and I have to brush clean between passes. rarely do I see a brand new Aluminum body that is made from sheet metal or round bar because the valve industry has really centered the product line to 9 1/4 and 2 1/4 Chromes, 316L,H and 17-4PH here @Emerson/Fisher, but like I said, most of the procedures I am required to use call for brushing between each pass no matter what the material is. Even hardfacing alloy 6. but I agreewith you, on a 4043 fuel tank or a toolbox, it would be a eye sore to see the dulled finish from brushing.
    Jan 2006
    In A Nice Comfy Chair
    We have been trying to convince Mr. Zap of that for years.
    But to no avail...
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Dec 2003
    Fairfield,CT
    Quote Originally Posted by TNwelder1985 View Post
    I find that if I don't keep the filler wire tight inside the shielding gas zone, it will always contaminate the puddle, keep that filler wire about 3/8 away from the puddle, because as soon as the wire leaves the gas, its oxidizing, which makes the weld harder to "clean" for the cleaning Action of the AC balance. Make sure to knock the joint with a dedicated brush that's for Aluminum After EVERY SINGLE bead. I also use a gas lens for pretty much everything, I like a #12 Cup on All pipe applications, and a #8 cup for Aluminum, with 3/8 stick-out on the tungsten, I only weld Aluminum with Helium. If your machine is a 165, helium would give you surprisingly more arc penetration than Argon could even dream of.
    I can take the filler 6" out of the gas zone and don't have an issue when I go to add filler. It is the angle of the dangle here.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Jan 2006
    I was actually putting it behind my back...
    Between each dip...
    At a class...
    And everyone saw it...
    And could not tell the difference.
    ...zap!
    Do not attempt.
  5. #30
    SoCal-LA
    Between each dip...
    At a class...
    ...zap!
Page generated in 1,624,195,163.85157 seconds with 12 queries
