Results 1 to 5 of 5
Thread: Grinding wheel recommendations?
    Sep 2008
    Dalton, GA
    Its time to replace my medium (60-80 grit) 8x1 grinding wheel on one of my bench grinders. I mostly grind steel welds with it. I know, a better welder should not have to grind welds, but this is a finished product and has to be blended smooth.
    I want a good balanced wheel that will last, but reasonably priced. I see brands listed for $20-200. I have a Dayton and a Baldor grinders that do a good job so I dont want just a cheap wheel.
    What brands and vendors do you recommend?
    Thank you for your input.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    10FtDrillBit.com
    Jun 2016
    Back to the jungle
    Re: Grinding wheel recommendations?
    May 2010
    ct.
    The last wheels I bought were from Enco.
    IIRC they were TruMax wheels. They are
    still working after several years of moderate
    use, so Im thinking theyre good.
    Now that Enco is gone I will probably get
    wheels from MSC when a free shipping
    and 15% off when ordering $100 or more
    type deal comes around. Ill just have to
    wait until I need $100 worth of stuff,
    Machine shop I worked in used Norton
    wheels, with few exceptions.
    I used bench grinder 36 grit for steel
    For hand grinding 24 grit and drill bit grinding 60 grit
    Sep 2008
    Dalton, GA
    The Norton green is rated for 3150 rpms, my Dayton is 3450 rpms. I see other wheels rated above 3450 rpms, but still trying to figure out which one.
    Ideas?
    Burt
    Millermatic 211
    Hobart Handler 120
    10FtDrillBit.com
Page generated in 1,624,065,086.23903 seconds with 11 queries
