Results 1 to 4 of 4
Thread: 200d uneven brushes
    Aug 2010
    200d uneven brushes
    I was just inspecting my brushes when I noticed that all of them are slightly tapered side to side toward the generator. One set is worse than the rest with maybe 3/16" of uneven wear. Its welding fine, but Im not sure if this is common, or a symptom of poor brush rack alignment or something similar. Any thoughts?
    May 2008
    Orange, TX
    Re: 200d uneven brushes
    Have seen this before. I suspect it starts due to the one or more brush springs being a little offset from center causing the brush to wear sideways.
    This one was still welding too believe it or not.
    Name:  Hardin SA200 001.jpg
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Aug 2010
    Thanks, that makes me feel better. Next set of brushes Im gonna try to figure out a spacer between the brushes to hold them true.
    May 2008
    Orange, TX
    Mmmm I'd be careful there. Could easily create a situation that causes them to hang up. I'd just make sure the springs are straight and centered on each brush.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,632,081,800.84538 seconds with 12 queries
