Results 1 to 25 of 26
Thread: The best 6 x 48 belt ?
    Mar 2005
    Under a Rock
    Picked up an old (1987) Grizzly sander...
    it's a wood model and turns slower than the metal beasts... but the price was right...
    Maybe I can get a bigger motor pully to get some more steam if needed... ?
    Anyway,
    Whats the best brand of belt?
    I figure maybe a 60 grit for steel?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Re: The best 6 x 48 belt ?
    Iíve been getting good results from Klingspor. Made in Germany.
    60 grit works well for me.
    Mar 2017
    bar stool
    I get the best results from the ones that are still glued together & recommend buying them in large quantity so the glue can let go while unused belts are being stored.
    Oct 2009
    Cartersville, Georgia
    I use Klingspor as well.
    Who is John Galt?
    Outside of Raleigh, NC
    I too use Klingspor. One suggestion - the shelf life of belts is around one year (but they typically last longer), so it’s a good idea not to buy too many at once.
    I like a mix of 24, 36 and 60 grit.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Mar 2005
    Under a Rock
    Thanks !
    Where are you guys buying these?
    I don't see them online anywhere ... in 60 grit.
    Hypertherm PM 45
    HTP 221
    Thanks !
    This prob doesnít help you, John but here in Western Canada KMS Tools carries them.
    I used to get them off the tool truck that called on the farm, but weíve both long retired!
    Jul 2014
    Bulldog Heaven at the end of my chain
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    Jun 2016
    Back to the jungle
    Jun 2011
    Aiken SC area
    Virgil, I can relate to that! Now I purchase two only at a-time. Bob
    Mar 2005
    Under a Rock
    Those look good quality!
    I think I am going to try the regular ceramic...
    I donít think this machine has the sack for a bora ceramic ...
    Hypertherm PM 45
    HTP 221
    Oct 2009
    Thanks !
    If you don't have a klingspor rep, they do sell them here.
    https://www.woodworkingshop.com/category.aspx?id=20&f1=6"+X+48"&f2=60+GRIT
    Who is John Galt?
    Mar 2005
    Under a Rock
    Thanks Bassboy.
    got em.
    Hypertherm PM 45
    HTP 221
    Thanks !
    Their sales rep stops by my shop monthly, so it's easy for me....
    If not then online at the Woodworking shop.
    Miller Suitcase MIG
    Lincoln 210MP
    Mar 2005
    Under a Rock
    Hypertherm PM 45
    HTP 221
    Aug 2016
    been using these zirconium oxide belts for several years
    https://www.mscdirect.com/product/details/85129088
    modified HF sander, 3 hp, about 2700 rpm, great for metal
    Name:  6x48 belt sander pulleys.jpg
    Charl
    Quote Originally Posted by xmmancharl View Post
    Charl
    What would that translate to in feet per minute?
    Mar 2005
    Under a Rock
    Charl
    What size was the original motor? how many RPM's stock?
    Any problems with the bearings? ... spinning faster?
    I might throw a bigger motor on mine If I find one cheap.... but for now I ordered a bigger motor sprocket... should double the belt speed.
    I like those link belts... got one of those too.
    Hypertherm PM 45
    HTP 221
    Jul 2007
    Lake Of The Ozarks MO
    If you use the orange Norton "Blaze" ceramic belts, its doubtful you'll ever use anything else again.
    They cut like crazy and last for a real long time
    Miller Dynasty 700
    Miller 350P with Aluma-pro push-pull
    Miller 280 Dynasty with expansion card
    Dynasty 200 DX
    MigMax 215
    Enuff power and hand tools to create one of anything..... but mass produce nothing!!!
    Nov 2016
    Mars
    3M 984f
    Mar 2005
    Under a Rock
    Doubled the speed,
    This thing kicks azz ...
    Ive got a couple Klingspor 9Ē discs coming too.
    I need to make a tool rest for the disc side
    Should come in handy ... that disc is Crankin now ...
    Hypertherm PM 45
    HTP 221
    Mar 2005
    Under a Rock
    I’ve been getting good results from Klingspor. Made in Germany.
    I see you have a dust collector on that kalamazoo...
    so maybe you don't notice...
    But I am getting a good amount of blue grit from the belt.... dust/debris etc.
    I am wondering if this is because the belt is new? maybe it calms down after break in?
    anyway, It seems to work great but I think I will be wearing a mask when using it.... just for good measure..
    I also am putting locking castors on it so I can roll it out to some fresh air... when possible.
    Hypertherm PM 45
    HTP 221
    Mar 2005
    Under a Rock
    Hypertherm PM 45
    HTP 221
    Aug 2016
    Did not put disc back on HF. Have dedicated 8 inch, 3,300 rpm disc sander for this.
    Original HF motor was 3/4 hp, 1,700 rpm, not much oopmh, even with different
    pulley arraignment. New 3 hp motor, 3,300 rpm.
    several years of use, still working good
    Charl
    Not sure what to say, John. I just tried mine with the vac off and itís okay. Belt is fairly new still.
Page generated in 1,624,063,495.88558 seconds with 12 queries
