Chop a SA 200
OK.How small can you chop a sa 200 to?Make in small as possible.
either you LIKE BACON or you're WRONG!!!! "There are three kinds of men.The ones that learn by readin'.The few who learn by observation.The rest of them have to pee on the electric fence for themselves"-Will Rogers
Re: Chop a SA 200
If you swap the engine for one of them Horrible Fright engines and change the generator to a inverter and use light leads you can get it small enough to fit in a Japanese convertible car.
One of the MessFit geniuses can help you with the electronics and it'll be able to burn 1/16 rods.
Add a thread spool from a sewing machine and call it a gas drive MIG.
Re: Chop a SA 200
5" is doable with the original fuel tank and would require a custom radiator or sacrificing the battery box.
Have seen 8" chops but they require a custom fuel tank in addition to a radiator and/or relocated battery.
This was a 5" chop with $500 custom radiator:
Owner started the project and I finished it.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Save Second Base!
Re: Chop a SA 200
Is a sweet running machine and owner sold it earlier this year as he now has an SAE300 Perkins and Miller Trailblazer Pro 350 with Kubota D905 I brought back from the dead last year. Just sent the 300 home the other day after addressing a few things on it for him.
Before . . .
. . . after . . .
Dodged the 16+" of Harvey water I had in the shop as she was up on jack stands.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Save Second Base!
Re: Chop a SA 200
Originally Posted by
duaneb55
Before . . .
. . . after . . .
I've never seen a better example of the results that are possible when a job done by someone who takes pride in what they do and is proud of the equipment they are repairing.
Re: Chop a SA 200
Can you show me how you did the gas tank? I’m having trouble with mine
Re: Chop a SA 200
The machine owner did most of the tank mounting and I just added a couple finishing touches.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Save Second Base!
Re: Chop a SA 200
duaneb55
thanks you do much!
