Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 501 to 525 of 530
Thread: Amazon Cutmaster 60i
  1. #501
    Re: Amazon Cutmaster 60i
    No it was melted off, you can't break off copper like that it bends. Try it with one of yours.
    Well..... if you're using the chinese import knockoffs of dubious alloys then it might break with mere finger pressure...
  2. #502
    Delaware
    Yea, your right there, you never know what it may be made of.
  3. #503
    May 2010
    Sparks, NV
    Re: Amazon/Thermal Dynamics Cutmaster 60i
    Just picked it up. Repaired under warranty. Said the pilot IBGT was bad.
  4. #504
    CT
    Question for anyone: What's the story with the 60iX model...seems like only Baker's Gas carries it. Is there a plan to release it to wider distribution like Amazon, welding supplies from IOC, Cyberweld, etc?
    Miller Multimatic 255
  5. #505
    May 2010
    Sparks, NV
    Oh tested it and no fault codes and it seemed to cut better without fouling the nozzle/tip. Infancy failure new thinks. Hopefully it will be good to go now.
  6. #506
    Jan 2005
    The China made 42 had a bad batch of boards that effected quite a few of the Green ones.. Seemed like close to the same issue. No pilot arc...Yep got lucky and got one.. All my 60i have been flawless so far.. You were fighting codes from the beginning with that unit..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  7. #507
    May 2010
    Sparks, NV
    Well I've used it a few times since the repair and all seems to be working as it should without any error codes. Much improved cut quality too
  8. #508
    Apr 2016
    CA
    Nice so now that it works as it should what is your impression of the machine. Worth the entry free you paid?
  9. #509
    May 2010
    Sparks, NV
    Biggest F'ing POS I ever bought. getting Error code 04, 05 with my gouging gun, 12, 14, 16 done all new consumables. This thing is going back to LWS tomorrow to be sent in again. Anyone want to buy this with probably less than 2 hours cutting time. Gawd I miss my old ESAB. thing was bullet proof compared to this POS
  10. #510
    Nov 2016
    New Hampshire
    So my 60i just popped. I pulled the trigger and got no arc, then a loud pop and that smell ......... error code E002. I called my LWS and they said that it has to go back to original vendor so I called Amazon and some guy I could barely understand allegedly has a replacement coming to me. I then got an email confirming a replacement was coming but that they couldn’t say when as they needed to get on in from thermal arc. I can fell an run around coming........
  11. #511
    Apr 2016
    CA
    Quote Originally Posted by winniweld View Post
    Dont jump the gun. Call ESAB for customer service support.
  13. #512
    May 2010
    Sparks, NV
    If it's under warranty that complete BS. Call ESAB. I bought mine on Amazon and had it repaired 2x at local LWS under warranty.
  14. #513
    Nov 2016
    New Hampshire
    So I took your advise and called Esab customer service,took it to my LWS who sent it to their repair center. Turns out it was a blown inverter board, repaired under warranty and back to me in 2 weeks working fine now.
    I’m wondering why ? It’s only 2 years old and it’s been used a fair amount but not excessively and not abused. Always used OEM consumables, anyone else have a similar problem?
  15. #514
    Apr 2016
    CA
    Was doing some cutting recently and trying to figure out the best way to calculate the straight edge for standoff cutting. I made a cut then measured the distance from the cut to the straight edge which gives me roughly about 3/16” of distance from my cutline to the straight edge for drag cutting with the stand off shield. Do this sound about right?
    putting this hear so I can print it out.
    https://www.rapidwelding.com/files/S...g%20Manual.pdf
  16. #515
    Hmmm.... not sure, but now you have me wondering how many cheap Chinese torches that cut off shield will fit...
    Jul 2016
    Midwest
    None of the Chinese torches will accept the TD parts but the TD torch has some china consumables options.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  18. Likes whtbaron liked this post
  19. #517
    Jul 2016
    Midwest
    You are using the Drag cap right? You don't have to under 60 amps but it works a lot better than trying to run the tip on the work or the nozzle rim on a straight edge.
    Cobra Pythons
    Victor Gas Apps.
  20. #518
    Apr 2016
    CA
    Yes the cap that has a cross section in it for sparks to shoot out sideways in 4 directions seen in image below.
  21. #519
    Jul 2016
    Midwest
    Yeah. Standoff cutting is kind of a humbling experience. I try to drag with these caps as much as possible. Good luck !
    Cobra Pythons
    Victor Gas Apps.
  22. #520
    Apr 2016
    CA
    My cuts are usually very clean imo. My biggest concern is getting the straight edge set with the correct amount of standoff so my cut line will give me exact dimensional pieces. I tried to find the amount of standoff or distance from cut line to straight edge in the manuals but came up empty so figured making a test cut with a straight edge then measuring the distance from the cut edge to the straight edge is about as good as it’ll get for now.
    Is there literature for this purpose that I have not read?
    Oh wait, perhaps my explanation is confusing what I am trying to say. I definitely am dragging my cuts with this set up mentioned in the above pic.
  23. #521
    I get what you're saying, the cup is placing the cut in the radius of the cup away from the straight edge. I just don't have a better answer for you than what you are doing by measuring a test cut. I suspect the literature isn't there because of the variables... after market cups v.s. manufacturer, solid area of a cup v.s. slotted area and angle of torch. To keep it consistent maybe you need something like a track holder to keep the angles from changing as you move.
  24. Likes N2 Welding liked this post
  25. #522
    Apr 2016
    CA
    Let’s not over complicate this lol. I was just curious if anyone with experiance using this set up knows the distance if all variables are correct. Factory consumables, flat 90 degree drag angle, air psi set at 115 to 120 at regulator machine set at 60 amps with 60 amp stand off nozzle used with drag cup. Perhaps a little more practice on my part and a note pad to document my settings and findings for future set up. I tend to forget these things pretty easy as I don’t use these tools very often, so when I do I have to read up on and learn it all over again. Just looking for a cheat code so I can get on with the day and get r done each and every time w/o a lot of relearning.
  26. #523
    If I'm understanding correctly you are looking for the actual cut kerf line from a straitedge. I would just take a small piece of 16 gauge or so, butt the straitedge to the edge of material and make a short cut. Take that piece, nip out on notch on the part away from the straitedge about half the length of the cut. Overall the piece would be small maybe 1" or 1-1)2" x 2" or so. This piece would then be set against or layout line where you want the cut. The notched out section allows for the kerf width, depending if it's an inside or outside cut. I would paint it I bright color so it doesn't get tossed and use it for layout instead of measuring the , for example, 3/16" or whatever standoff is required.
  27. Likes N2 Welding liked this post
  28. #524
    Jul 2016
    Midwest
    I use a Tangent straight and circle cutting kit. You still need an edge to run the wheels on though. It tends to give less jerk that a drag cut.
    Cobra Pythons
    Victor Gas Apps.
  29. Likes N2 Welding liked this post
  30. #525
    Apr 2016
    CA
    Had to cut 5 bolts from a '95 ford bronco rear bumper to bracket yesterday. Decided plasma gouging was the way to go. At first the machine did not want to work. Had to remove the nozzle start cartridge etc to get it to work then it stopped again giving the same error code ending in 12. Pulled the gun off of the line and noticed the middle pin hole of the 5 pins was sticking up or out closer to the edge of the connector than the other 4 pin holes. Can't remember if it was the gun side or hose side. Put it back together and was able to blast through the bolts pretty efforlessly at 60amp. Gouging rocks as does the machine when it works like it should. Connections are very finiky.
Page generated in 1,713,287,862.73395 seconds with 20 queries
