Page 1 of 21 12311 ... LastLast
Results 1 to 25 of 524
Thread: Amazon Cutmaster 60i
    Jan 2005
    Amazon/Thermal Dynamics Cutmaster 60i
    This cutter could be a deal for someone.. You have to get it quick before Amazon jacks the price out of sight. I picked one up at $1355.21 (Amazon Prime price) Which really is about as low as it might go. , It started out at about $1500 something ,and dropped to $1355.21 this morning Might of dropped lower, but some smart guy always nails it before that happens..
    https://www.amazon.com/dp/B079Z3W7HB...v_ov_lig_dp_it
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal LM-200/ Lincoln feeders
    Thermal 95s
    Thermal 60i- 3phase /RPC powered
    Thermal Drag-gun 35C
    Thermal 15c
    INE 1500
    Klutch 140i
    CT
    Re: Amazon Cutmaster 60i
    Scott, does Thermal Dynamics honor/support the warranty if you buy from Amazon? is there any risk there?
    Miller Multimatic 255
    Jan 2005
    Yes they do.. no risk
    It's 4 years too.
    I was thinking about you when I posted it..seems to be holding in price also..
    I am selling my 45XP to go with the Thermal machine. Great machine too, just does different things I really don't need at the moment.. I want to be able to run the small torch with 60i, and something not possible on the 45XP. Not a knock, just want to use the SL-40 on sheet metal type stuff.. The 45XP gets good consumable life, but the victor stuff is really cheap on e-bay.. Kind of a wash for me.. Have tons of both anyway.
    I have a cnc interface for the 60i, and it will work on my cnc table. So with my SL-100SV torch, not losing too much on the table,Some gain and some loss. Want the extra arc length the 60 I will provide. cutting thicker stuff will be a bit easier running at .1900 off the plate instead of the .060 of the Hypertherm. Mostly that, and thick it will be a bit easier in that one application. Find out anyway.. Fan will be louder, but since I run fans to pull the cnc cutting fumes out, no issue with that one either.
    It's lot of machine for the money. Made in North America too.. (Mexico)
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    CT
    yeah, that's a hard to beat price. The best price I have seen on a Hypertherm 45xp is $1860.
    Jan 2005
    Mine is $1990 with the cpc connection.. Bought it with the gouging torch/hand torch/cpc for $1910 I believe? Good price, and should sell at $1500 with some extra consumables/Hand torch only. Going to give the gouging torch to a friend,unless he want the whole deal.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Mar 2017
    bar stool
    Little trick to Amazoomie; look at any product and a couple similar products and sit back. Their system will begin sending you lower and lower prices beginning about 30 hours after first look if they show inventory levels not dropping as predicted.
    TD is now an ESAB product as I recall. I wouldn't be too sure it's made on this continent, more a chance the container from the far east was dropped here.
    Apr 2016
    CA
    How are consumables for drag cutting?
    Jan 2005
    Quote Originally Posted by Virgil5 View Post
    This one is made in Mexico. like all the larger cutmaster's. 42 is China, and 15c, 35 built-in air ones are Korea (about 12/13 years now..
    The 60 amp straight drag work somewhat ok with the standard 9-8218 cup, (40 amp too) Shielded drag is your best consumable life, using the 9-8237 cup, and 9-8244 /40 amp/ 9-8235 60 amp drag shield combo. The straight nozzle 40 amp un-shielded gives you the best view over any other design from anyone out now. reason I use the SL-40 torch over my Hypertherm 45XP on sheet-metal (38XL) I use what works for me, and not what other people think is best for me.. Llike your Esab PT-31 with the XT consumables
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Apr 2016
    CA
    Yeah I used it recently and am getting better at it. Since it is HIgh Frequency I was under the impression I had to maintain tip to work contact at all times. So you can imagine how I was going through consumables and scared to use it as it was eating through my wallet. I recently tried cutting with an 1/8” to 1/4” stand off after intiating cutting flame and the consumables tend to last longer. Still not great at it but getting better.
    Nov 2016
    New Hampshire
    Brand X, Ive been looking at plasma cutters for a while off and on and i'm considering the 60i and the 45 XP. I have to say thats a pretty good price, i usually see them around $1700. I have a cheap plasma but for whatever reason it doesn't run well at all off my trailblazer and i'd really like to have a plasma cutter that i can carry to the job site and count on to work as it should. Have you tried the TD unit off a generator or do you have any idea if it will work in a mobile application off a trailblazer?
    Jan 2005
    Quote Originally Posted by winniweld View Post
    I have not used either the 45XP or 6i on a genny. Put a meter on the 45XP, and it's excellent in amp draw. From what I know the Thermal should be the about the same..You can fudge the # a bit by keeping the arc length short as possible, and with the different torches on the Thermal it should really be genny friendly I played with the SL-40 torch, and noticed huge differences in running different consumables. Main thin is the power supplies on both as about as good as it gets genny wise.
    Cutmaster shows tomorrow. It's down to $1319.92 now.. Ordered mine Sunday, and will be here on Tuesday. I will have both here, and can run some input/ output tests tomorrow. My guess is the trailblazer will run both machines at least to their rated piece thickness.. Maybe beyond if you setup the consumables corectly.
    All the thermal plasmas have ran well on the genny's i had them with.. Same with the esab machines.. More of a matter of full power or not.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Feb 2015
    Don't forget about the $130 rebate on the 60i from ESAB. The catch is you have to buy an A50 welding helmet also...
    Nov 2016
    New Hampshire
    I appreciate the offer to run the tests on the 2 units, at 1319 i might just have to upgrade to the Thermal Dynamics unit..... Any other thoughts or impressions you could offer on how the 2 machines compare would be great.
    Thanks
    Jan 2005
    The 45XP will have some advantages because of all the different consumable designs. Just a much more modern torch.consumable design. Cutting stuff in normal fashion, the more powerful 60i should have a edge in longer arc length on the extreme edge of performance. I expect on 1 inch they both can cut 1 mild steel at a best quality speed of 3 ipm
    The arc will probably blast through the bottom of the plate a bit better on the Thermal unit. That is where I will test for amp draw,and will give the two power supplies a work out
    I am setting mine up for cnc work, and have a lot of experience with Thermal machines, That means the inherit advantages of the 45xp there will just be less of a factor in me using one. Most people it would not be the correct pick for them, but I am not most people or do production work on my table.. Just my own use type of things mostly.
    I don't expect the 1219 price to hold much longer. Probably for the next guy to pull the trigger, and that's about it. Sit on the fence, and you can loose out at amazon.. From what i have seen anyway.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Jan 2005
    $1306.99 right now..Getting to be a steal, for the next guy to pull the trigger. Keeps going down,and I will buy that one, then send mine back.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Nov 2016
    New Hampshire
    its back to 1342 now.......
    Nov 2012
    Now at $1,429.89. (One hour and 20 minutes later.)
    CT
    I hesitated. I should have grabbed it at $1319 and used my employee discount on it. But I am in no hurry. I think the black friday deals will be even better than this to tell the truth.
    Jan 2005
    It will probably never be this low again. (IMO)
    I did hook it up.. It's awesome. it even supports my SL-40 torch.. (40 amp max) The 1 inch @60 amps output will draw between 39-42 amps input/240 volts. I ran some 50/55 tips @50, and it dropped it down to the 35 peak input range. Probably better to use those nozzles over the 60 amp ones if you what a bit less draw, and keep the performance up..It really is a powerful arc even with the old torch tech. Hypertherm 45xp is on the way out. Nice,but the Thermal does what i want it to do.. started hooking up to the cnc table now..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Jan 2005
    Setup for the table almost. Just have to hook up the two trigger wires to the #3/#4 pins on the J609 terminal. Have to figure out some kind of decent plug to it.. There is arc good on the same terminal, and full arc voltage too.. Just used a CandCnc voltage divider in the unit, and their arc good setup I had..Works well.. The machine auto senses the machine torch with a valve, and sets it up to use. Does not show on the front of the machine, until you plug that torch in. Thought they killed that option, would of sucked too..
    There is no CNC stuff for this unit, although it's all wired for it in the future..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Jan 2005
    Chris,
    put this info/ thread up on the cnc place.. Just to make it easier for people to run the 60i on a table.. Really happy with the power, and the old Thermal SL-100SV torch..
    http://www.plasmaspider.com/viewtopi...161388#p161388
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Feb 2016
    NW Ohio
    It's over 1800 today.
    Mike
    Esab Rebel 215
    Lincoln Weldanpower G7
    Plenty of grinders, hammers, pry bars and beer.
    Dec 2009
    Scott ,,your timing could hardly be better picking that up off Amazon,,great score!! nice machine
    Esab Multimaster 260
    Esab Caddy160I
    Esab 161 STL
    ESAB powercut 650
    Esab 220i tig
    Lincoln Precision Tig 225
    Lincoln IdealArc 250
    INE SKYLINE 1500
    Klutch 140i
    MEASURE TWICE IS FOR MORONS
    Jan 2005
    Quote Originally Posted by jim cafarelli View Post
    I could of bought one for $40.00 cheaper. but you know Amazon. kind of crazy if you wait just a bit too long. At least people had a chance to get in on it,so best I can do..Was going to e-mail that deal when it first showed, but I think you really have the best machine for your type of work.. You would set one up with a SL-40, just so it would work in tight places that your PT-31XT would..Anyway, thought you really don't need the extra power at all..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal 95s
    Thermal 15c
    INE 1500
    Klutch 140i
    Feb 2015
    Chris,
    Scott,
    I saw your post and when I looked at the price is was just over $1300. I almost put it in my cart and checked out since when I used it at fabtech in 2016 I knew it had a nice long arc and great for hand cutting. The ESAB stuff has turned out to be good equipment for me. I probably could have talked myself into it since I sold the cutmaster 52 recently.
    I seem to be spending more money than I need lately, and just a few months ago bought that 45xp and then dragged home a larger 10x52 mill, still debating if that was needed. Steel and aluminum has gone up here...damn tariffs.
    I have mastered plasma marking on the 45xp, or at least I think I have. Good enough that people are pleased with the look and making money from it. I use lots of argon though since my trick is to slow it down and run it twice on each piece. I finally got rid of any divots that are easily visible.
Page generated in 1,638,021,585.22936 seconds with 12 queries
