Results 1 to 9 of 9
Thread: When sMIG Has No Voltage Limits
    Feb 2015
    My sMIG has been kind of acting strange on one of my Rebels, voltage has been jumping for no reason. Well today it decided to go into full on beast mode at 37.7 volts when set for 14ga, burned the wire back into the tip then shot out a flaming ball across the shop, picture was taken right after the fireworks, amps dropped off. Blew a hole right through one of the awning braces I was making also. I am sure it's going to die soon, it's jumped to 29 volts before but this is getting crazy!
    I will give ESAB a call this week and see what might be the problem.
    Apr 2016
    CA
    Re: When sMIG Has No Voltage Limits
    That is pretty crazy. I have had the opposite happen with mine. Voltage drops way to low causing very cold or poppy welds.
    Feb 2015
    ESAB had not heard of my problem, but did learn there is a system reset in the setup options (probably should have looked first). I did the reset and welded with it a few hours and did not have any problems so far. I got some good info on the Rebel boards and software. ESAB Technical service is top notch, said if I did have more problems to take it in and they would load bank it, update the software if needed, and check the boards.
    Apr 2016
    CA
    what is load bank it? Max it's load and see what it does?
    Jul 2014
    Bulldog Heaven at the end of my chain
    Exactly but not only to ensure it will make current, but hold it too.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    Apr 2016
    CA
    Quote Originally Posted by Slob View Post
    Good info thank you
    Apr 2016
    CA
    Any updates after the reset? Did you reset it from the control panel?
    Feb 2015
    Unit seems to be back to welding fine, no issues since the reset.
    I did reset from the main control panel. I had to go back in after and set up all my parameters and presets again.
    Apr 2016
    CA
    Ok just checking. Think I will try a reset next time I use it.
Page generated in 1,628,000,198.93941 seconds with 12 queries
