I am hiring Pipe Welders/Fitters & Semi-Auto TIG Welders!!!
Location - Cambridge
Permanent positions
Test details are below:
Pipe Welder/Fitter -Test 37 for RT/UT welder is a 2-3/4"OD Pipe .625" wall thickness welded in the 6G position with SMAW (stick electrode). The root has been already been deposited by another welder. The visually accepted weld is then RT volumetric examination.
Semi-Auto Welder - Flat groove - GTAW (TIG). Malt steel is the material. Client will be assessing how the candidates deposit (using semi- auto welding machine) the welds in the proper position.
Call me for more information on ---> 647-6497909
