Re: Is an oldschool Kalamazoo 300 band saw any good and worth fixing up?
Originally Posted by
N2 Welding
What would you do for cutting flat stock. Stand the piece up vertically or lay it flat? I understand if the piece is wider than 6" I have to lay it down. Just figured I'd pick your brain.
Depends on size in regards to thickness. I often cut 1/2" x3 or 4" upright. I wouldn't cut less than 1/4" thick upright unless I was ganging pieces together. Blocking up the fence side helps when cutting flat stock on the flat, as it allows less teeth in the cut when exiting the cut. More important to that is being able to properly secure your work, as any shifting can strip a blade in short order.
