He fellas - bought some 3/32 and 1/8 auminium electrode sticks on amazon.. Tried some this evening - what a mess.. Experimented between 55 and 85 amps.. had positive electrode, seems others have had much better luck than i have:
http://hildstrom.com/projects/stickaluminum/
Every time I get the arc started it dies and the tip is full of flux (scrape off on coarse stone / try again - same thing).. I might try angle the stick forward instead of dragging it like stick..
and the most current review on amazon for the same sticks reads:
"This is fantastic. Everyone says you need fancy equipment to weld aluminum. It is just not true. This stuff works great with (DC electrode +). In only have an AC buzz box and thought I'd give it a try. It doesn't work. You can not keep an arch with an AC machine. I rented a DC welder for $35 and it worked perfectly. I was amazed. I am not a good welder and it because of that, it didn't work perfect, but it sticks. I am sure a good welder could lay a great bead with this stuff."
Product link here:
http://a.co/d/0P66VCF
My welder is a little CT-312 110v inverter DC welder -
any help appreciated! Im plugged into a 30a socket (no leads), clean ground clamps / etc.. Thing is my test piece was a volvo penta boat exhaust, not sure if they used some special alloy perhaps - not that I would even know where to begin -
If i could get ANYTHING as close to this guys welds id be more than happy -
Product link here:
