Results 1 to 5 of 5
Thread: What is a Momentary arc start?
    Mar 2005
    Under a Rock
    What is a momentary arc start switch VS a sliding type amp controller or something like the tig button for a tig torch?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    CT
    Re: What is a Momentary arc start?
    Its for triggering 2T/4T sequences. Or for blasting tack welds. Its just an on off contactor switch really
    Mar 2005
    Under a Rock
    OK thanks...
    I believe my HTP221 has a setting for something like that... (spot)
    I was just curious..... I'd like to try a tig hand control someday.... tig button looks cool...
    but CK or HTP makes a sliding wheel thing too.... although it borders on cumbersome... so it seems ... by looking at it
    Hypertherm PM 45
    HTP 221
    CT
    Your HTTP for sure has a sequencer. The momentary switch activates the functions as follows:
    "When you depress the trigger on the torch, your Invertig 221 provides pre-gas flow for as long as the trigger is depressed.When the trigger is released, it will slope up to the welding amperage that has been selected. When the trigger is depressed again, the welding current will slope down to the final current. As long as the trigger is depressed, your Invertig 221 will continue to weld at the final current which has been selected. When the trigger is released, the arc will extinguish, and the post flow will start. Welding parameters which can be adjusted using the encoder are slope down (2E), final current (2F), slope up (2C), starting current (2B), pre-gas (2A), and post gas (2G). Again, we do not recommend using the 4t mode with either the foot pedal or the torch mounted amperage control."
    Jul 2018
    Cumbria, UK
    in UK for pipe welding we nearly always have a button on the torch for 2T/4T and rarely, if ever, use a pedal.
Page generated in 1,624,503,840.71848 seconds with 11 queries
