Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Here....Hold My Beer....
    Jul 2014
    Bulldog Heaven at the end of my chain
    Re: Here....Hold My Beer....
    Good job Zap. Should serve the purpose well.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    May 2008
    Orange, TX
    The guy heard you get all the fun jobs and wanted to keep you happy. Figured you could just bevel a little and weld it up with a 120V Harbor Freight flux core unit then grind until the bearing fit. Done and done.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jun 2011
    Aiken SC area
    How did you keep the rubber from burning/melting or did I miss something? Bob
    Nov 2012
    new york city
    Figure overall length from head.
    Steady rest what is there.
    Center drill..
    Face sawed off ends till flat face.
    Drill with one inch drill 3 inches deep.
    Bore until happy with finish.
    Measure bore depth.
    Figure what you need for overall and add bore depth.
    Make new ends from stock 1/4" bigger than finish.
    Turn stub to length of bore and leave it .003 over.
    Heat bore with rosebud.
    Insert end with proper weld prep area.
    Let cool till end gets tight.
    Weld accordingly.
    Do both ends.
    Re install in lathe and steady rest same place as you bored it.
    Center drill
    Face to length.
    Finish to size...(1.9375)
    Add 1/2" X 4.25 long keyway to long journal.
    Pics tomorrow if it is still there.
    That about cover it?
    8 hrs.by the way since I opened the box.
    ...zap!
    zap;i could think of worse ways to kill an 8 hour tour.
    i.u.o.e. # 15
    queens, ny and sunny fla
  5. #30
    Jan 2006
    In A Nice Comfy Chair
    Quote Originally Posted by rhunt View Post
    Hot hot hot only on the bore.
    Get that rosebud CRANKIN!!!
    Heats bore to red in 30 seconds.
    Insert end.
    The new shaft and the thickness of the heads and roller keep the rubber from excess heat.
    This rubber can put up with a fair amount of heat...
    It's a hot glue squish roller for plywood.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
  6. #31
    May 2010
    Ct.
    Was that roll being removed so it could
    be resurfaced? Rubber looks like operators
    used a razor knife to remove wraps/jams.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  7. #32
    Jan 2006
    Quote Originally Posted by jpump5 View Post
    Beats me....
    ...zap!
    Do not attempt.
  8. #33
    city of Four Flags
    Prolly just where the recip saw slipped
    Nice work as always Zap!
  9. #34
    Nov 2004
    Southern Montana
    Bet your beer went flat.
  10. #35
    Jan 2016
    Manitoba , Canada
    Learned a bit more , like school here , but interesting
    1963 SA200
    MILLER SYNCROWAVE 180
    THERMAL ARC 180
    HYPERTHERM POWERMAX 800
    DECKEL FP 3 MILLING MACHINE
    ZUBAL 14-40 LATHE
    BEER FRIDGE
    Hobby kinda got away on me
  11. #36
    Apr 2016
    CA
    & warn >-<
Page generated in 1,713,293,215.73441 seconds with 18 queries
